can't open door
Old May 23, 2011 | 09:27 PM
billlee's Avatar
billlee
Default can't open door
I have an 81, the passenger door will not release, seems to be locked, have tried to unlock and go through window to release lock,,,,any ideas? getting desperate.
thanks
Bill
Old May 24, 2011 | 06:52 PM
captl27's Avatar
captl27
I have had the same problem with my 79. The only way i was able to open the door was to lower the window and take a bar push past the plastic lock cover and jimmy the springs in the lock mechanism while turning the key until it released the lock. It did work eventually and then I took the lock lubed it up and now it is working fine. Good luck
Old May 24, 2011 | 07:57 PM
75myway's Avatar
75myway
i had the same problem on my 75 when i got it. Called the PO to verify the problem as it worked during the test drive. He said to put the window down, get a can of white grease aerosal and spray it on the door rod & internal handle mechanism. Work the handle many times as you are spraying the grease. Then get inside the car and push out with your shoulder as you hold down the handle. Mine has worked ever since.
Old May 24, 2011 | 08:56 PM
billlee's Avatar
billlee
Thanks guys,,,,I'm back to a 2door
pb blaster, then lithium grease did the trick
Old May 25, 2011 | 02:56 AM
battsup's Avatar
battsup
In case anyone else has this problem make sure your handle is popped up fully. The handle linkage binds with the door lock linkage and prevents the door from being unlocked. I got mine open by undoing a coat hanger and making it into a V, sliding it around the lock linkage(verify with the other side) and then yank up real hard. Then I took the door panel off and lubricated everything nice and good.
To can't open door
