I was thinking about that and I did some intensive researches for about a year, the conclusion was to invest $100 on some new hoses, fittings .. etc and have the original system work as it should, and its working like charm ever since in a daily driven car.
Hi keith,
I agree with Ham.
The headlights are often much easier to get working,and keep working, because they're not as complicated as the 68-72 wiper door.
Have you tried to trouble-shoot what you have?
Regards,
Alan
Although there was a guy on the forum that made brackets to use with Firebird motors that ended up under 1000.
What's the motivation for the change? (Lighter weight, reliability, cost...???)
Just one opinion,hopefully others will give theirs.
My feeling is the unfamiliarity of how it works and simplicity. I don't know for sure but I doubt the weight would be an issue,it can't be reliability,cost is not even close.
As for the reliability, the chance of having a vacuum leak in that area is the same as having a peace of wire shorted to the frame, so IMHO, the stock factory system is no less reliable anyway, and the stock vacuum actuators weigh far less than any electric motor, and costs 1/10 less.
I've bee wondering about electric headlight actuators also. I am a little concerned that my new motor may be a little shy on vacuum to operate them correctly.
