Steering vibration at 80mph
Old May 25, 2011 | 11:25 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default Steering vibration at 80mph
I'm getting steering vibrations @ 80ish mph.
Suspension and steering are all new (VBP monoleaf and rack attack).
Alignment was done a few weeks ago and I was under the front end last weekend, all the kibbles and bits are snug.
Leads me to believe there is a wheel out of balance, but I didn't have any such vibrations last summer.
Any other thoughts as to what it could be?
Old May 25, 2011 | 11:37 AM
Jim Shea's Avatar
Jim Shea
How old are your tires? Could be a symptom of ply separation. Tire tread that is just starting to separate from the tire carcass may only show up at high speeds.
Jim
Old May 25, 2011 | 11:46 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Unknown, came with the car when I bought it in '09
Is there a way to tell, or do I need to take it to a tire shop?
Old May 25, 2011 | 01:18 PM
...Roger...'s Avatar
...Roger...
Tire shop will be the easiest but you could start swapping tires until you find the culprit.
Old May 25, 2011 | 01:30 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Tires are dated. Find the DOT block and look for the date code.
Old May 25, 2011 | 01:56 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I wonder if DOT codes appear in Canada, I'll have a look after work
Old May 25, 2011 | 02:33 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
wheel bearings....are a possibility
Old May 25, 2011 | 02:35 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
And with sidepipes, I'm guessing I won't hear the droning noise they normally make eh?
Old May 25, 2011 | 02:37 PM
mauiwilly's Avatar
mauiwilly
Jim
If you don't find the DOT week/year stamp on the outside of the tire that means that its on the inside....and that means pre-2000 ! Just replaced my tires which looked brand new but turned out to be 12 years old....HUGE difference in ride and handling as well as safety factor !......lots of posts on tires in the Forum. Most tire guys will tell you 5-6 years max life no matter what the mileage is on them....( I was shocked as well when I did my research !)
Mark
Old May 25, 2011 | 04:40 PM
Jims66's Avatar
Jims66
I experienced the same thing (old tires)..... Put on new and the problem was gone.
Old May 26, 2011 | 07:49 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
c284100
41st week, 2000?
Old Aug 16, 2011 | 09:57 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
update:
New tires and the vibration is gone.
Old Aug 16, 2011 | 11:22 PM
tortisevette's Avatar
tortisevette
try 100ish maybe it'll smooth out.
Old Aug 16, 2011 | 11:54 PM
TedH's Avatar
TedH
Glad the tires solved it. Had same problem with front tires back in 2005. Replaced them along with all 4 new shocks (KYBs). Old ones (now those are getting old and I've barely driven the car in... six years.... my rear tires are about 2000 vintage) had cupping/feathering on the tread. Smooth as silk right up to 120+ now
Now that I'm working, I should see about replacing the rear tires with a fresh pair at least (rotate the 2005 vintage tires, front to rear at the same time)
Old Aug 18, 2011 | 03:08 AM
Clubby99's Avatar
Clubby99
No problem. Just follow the speed limit.
To Steering vibration at 80mph
