Resurrecting my 1970
Old May 26, 2011 | 12:36 PM
RescueDad's Avatar
RescueDad
Default Resurrecting my 1970
Hey everyone,
This weekend myself along with my cousin and brother-in-law will be resurrecting my late father's 1970 Vette (he just pasted away this January). The car has been sitting in a conditioned garage since about 1989. We rolled it out a few months ago to give it a much needed bath. At that time, I gave it a quick once-over and I was surprised at the apparently good condition that the motor, and the rest of the car was in.
After much research on the forum, I have our list of to-do's. We'll be changing all of the fluids, rebuilding the calipers, changing spark plugs, flushing the coolant system, priming the oil pump, fogging the cylinders, etc. Any other words of wisdom would be greatly appreciated.
I'll be sure to post an update next week.
Old May 26, 2011 | 03:38 PM
Q's 68's Avatar
Q's 68
Sorry to hear of your loss. That has been sitting unused??? Nice to see it back out.
Old May 26, 2011 | 04:08 PM
RescueDad's Avatar
RescueDad
Thanks for your condolences Q. I'll try not to let it go unused for that long again.
Old May 26, 2011 | 04:19 PM
Alan 71's Avatar
Alan 71
Hi rd,
Nice looking convertible.
It'll be interesting to hear how you make out.
If it was stored in a friendly environment, it just might come back to life pretty easily!
Good Luck!
Regards,
Alan
Old May 26, 2011 | 05:46 PM
speedreed8's Avatar
speedreed8
i would check the condition of that rubber fuel hose going to the carburetor. i would change it out with at least some stainless steel braided hose. fyi. good luck, nice looking car. (sorry for your loss.)
Old May 26, 2011 | 06:25 PM
LancePearson's Avatar
LancePearson
Looks good....is a set of modern wheels in your future or is some part of the wheels on it missing? They look like just plain old painted steel wheels in the photo and a set of modern wheels of your choosing will make that car "snap" in appearance imho.
Nice looking Convertible.
Old May 26, 2011 | 06:37 PM
udornf4's Avatar
udornf4
Default fogging the cylinders???
I've been around car restorations for a long time. I've never heard the term "fogging the cylinders". What in the world is that?
Old May 26, 2011 | 07:13 PM
calif phil's Avatar
calif phil
That is when you spray fogging oil into the carb throat and or each cylinder to combat moisture before putting it up for storage. It will help if there is a bit of rust in this case by giving the cylinders lots of lube before cranking it over.
Old May 26, 2011 | 10:26 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Welcome! Lots of good info here. Nice car.
Old May 27, 2011 | 02:23 AM
68/BB's Avatar
68/BB
How do you apply it?
Old May 27, 2011 | 08:14 AM
RescueDad's Avatar
RescueDad
Good idea. I sure dont' want fuel spraying everywhere.
Old May 27, 2011 | 08:17 AM
RescueDad's Avatar
RescueDad
The wheels on the car are actually Corvette rallys, they have just been painted and are missing the trim rings and center caps. Actually, they aren't missing, I have them in the garage. My dad removed them when he used to auto-cross. Eventually I do plan to repaint them back to silver and put the rings and caps back on along with new rubber.
Old May 27, 2011 | 08:19 AM
RescueDad's Avatar
RescueDad
The fogging oil comes in an aerosol can and has a small straw, similar to a can of WD-40. Prior to start-up, you simply remove the spark plugs and spray into each cylinder. You can turn the motor over by hand and reapply.
Old May 27, 2011 | 08:41 AM
LancePearson
better idea is to have a metal fuel line fabricated for it. All risk and no gain with rubber at the engine on a fuel hose.
Old May 27, 2011 | 08:56 AM
Lemans Blue 69's Avatar
Lemans Blue 69
Am I missing something in the 1st picture? The grille on the fender looks like that of a 73 which only had a chrome bumper in the rear.
Old May 27, 2011 | 09:44 AM
BBCorv70's Avatar
BBCorv70
Looks like a 73 nose, no egg crates, just slots.
Old May 27, 2011 | 10:56 AM
RescueDad's Avatar
RescueDad
I was waiting for someone to mention this. The car is indeed a 1970, I have the VIN to prove it. VIN No. 194670S410573. My father removed the louvers and had the fenders fiberglassed to resemble a '73. Don't ask me why though.
To Resurrecting my 1970
Old Jun 1, 2011 | 12:56 PM
RescueDad's Avatar
RescueDad
It was a success!!! The Vette is running again after her 20 year hibernation. Everything went as close to plan as could be expected. The only real snag we ran into was a leaking master cylinder. This was only a minor setback because no one had a rebuild kit in stock, but fortunately my brother-in-law made a few calls and found a remanufactured MC nearby. Breifly, we changed all of the fluids (trans, diff, oil coolant), change the plugs, fuel filters, strainer sock, new valve cover gaskets, rebuilt the callipers with o-ring pistons, new SS brake hoses, fogged the cylinders and pre-oiled the motor among a few other things. I'm posting a few pictures from this past weekend, and I'm going to try and post a video. Thanks again for all of the helpful info on this forum.
This piston came out of the right front calliper. This was by far the worst. All of the callipers now have new O-ringed pistons and stainless steel brake hoses.
We recovered the build sheet, but it's hardly ledgible.
This is her first time out in public since about 1989.
I think it was very fitting that we were able to drive the car on Memorial Day, since my father was a Vet.
Old Jun 1, 2011 | 12:58 PM
RescueDad's Avatar
RescueDad
And here is a video I put together. I hope it works.
http://s1207.photobucket.com/albums/...vetteMovie.mp4
Old Jun 1, 2011 | 01:04 PM
RescueDad's Avatar
RescueDad
To our supprise, everything seemed to be in working order. The headlight actuators, wiper door, all of the guages and even the clock.
