Auto Trans Shifting into High @ 26mph +/-
Old May 26, 2011 | 10:43 PM
Mark Hawkins's Avatar
Mark Hawkins
Default Auto Trans Shifting into High @ 26mph +/-
Hey Guys. I have an 81 that I have been working on due to the prior owner not providing enough TLC. Anyway, the car shifts into high gear around 26-28 mph when driving in a 25 mph zone. Is this normal? I kind of think it's atypical but you guys are the expert. Thank you in advance for your opinion. I have changed the trans filter and put mobile 1 synthic in it. Lord, that stuff smells like it had been burnt before they bottled the stuff.
Old May 26, 2011 | 10:57 PM
7T1vette's Avatar
7T1vette
THM-350 with a 2.73 rear gear upshifts 2-3 between 21-29 mph; with a 3.08 rear gear it upshifts between 18-26 mph. Sounds like yours is about right.
Old May 26, 2011 | 11:52 PM
redvetteman81's Avatar
redvetteman81
I also have an 81 and that sounds right.
Old May 27, 2011 | 12:28 PM
Mark Hawkins
Good deal. Thanks a lot. Good to know that something is working right.
Old May 27, 2011 | 12:45 PM
qwank's Avatar
qwank
My 81 does the same thing. also the converter is locking up at that speed also so it makes it feel even wierder.
Does anyone know if installing a shift kit will make it hold the gears longer?
Old May 27, 2011 | 02:57 PM
hugie82's Avatar
hugie82
The weights and springs on you govenor will affect the high speed shifts and on a th350 the modulator has a small screw you can play with to change the shift timing. I forgot which way to turn it but you can't screw it up, it only changes the shift by 3-400 rpm
To Auto Trans Shifting into High @ 26mph +/-
