power window
Old May 30, 2011 | 07:31 PM
Steve144's Avatar
Steve144
5th Gear
Default power window
How can I tell if my window switch is bad or my widow motor? It is stuck in the up postion.
Old May 30, 2011 | 07:39 PM
terry82's Avatar
terry82
if you have power to the switch but not to the motor ,i would think switch .but then i would run a hot wire to the motor and check.
Old May 30, 2011 | 07:59 PM
...Roger...'s Avatar
...Roger...
but you can also pull the blue/brown wire connector from the motor and check for power while operating the switch. 1 wire is up and 1 is down,motor case is grounded
To power window
