Control arms
Old May 31, 2011 | 11:21 AM
JER BEAR's Avatar
JER BEAR
Default Control arms
How is the best way to get bushings out of upper and lower arms out?
Old May 31, 2011 | 11:29 AM
BC78vette's Avatar
BC78vette
I'm planning on starting a front suspension rebuild on my 78 in a few weeks. I have spent the last year planning and buying tooling - so far, I've found the best explanation for control arm bushing removal to be here:
http://www.corvettemagazine.com/susp...n-rebuild.html
Old May 31, 2011 | 11:54 AM
JER BEAR's Avatar
JER BEAR
Originally Posted by bc78vette
i'm planning on starting a front suspension rebuild on my 78 in a few weeks. I have spent the last year planning and buying tooling - so far, i've found the best explanation for control arm bushing removal to be here:
thanks, looks like a good site
Old May 31, 2011 | 07:06 PM
Solid LT1's Avatar
Solid LT1
Air compressor and pneumatic air chisel is the best solution. Can you say BRAAAPP!!!
Old May 31, 2011 | 10:37 PM
terry82's Avatar
terry82
http://www.digitalcorvettes.com/foru...d.php?t=141670
Old May 31, 2011 | 11:58 PM
mr. creosote's Avatar
mr. creosote
Not having a press, I used a drill to cut up the rubber of the bushing. Then, slowly picked out the rubber piece by piece. It took a little time, but wasn't difficult. For the outer sleeves, I highly recommend using the air chisel with a couple squirts of PB Blaster to help.
I then sand blasted 'em, painted 'em real nice and took them to a frame shop to press in the new ones.
To Control arms
