Manual transmission fluid??
Old Jun 3, 2011 | 03:44 PM
scottyp99's Avatar
scottyp99
Originally Posted by Mike Ward
I could have sworn the OP said that she has an '81 w/4speed. No mention of any modifications.
Who gives a sh*t what other makes/years of cars with other transmissions use?
You are correct, and for what it's worth, concerning his '81, I would use whatever the service manual said to use. If you don't have a service manual, get one. Haynes and Chilton both make a good one for our cars.
I just mentioned my brother's '97 because some folks seemed incredulous about ATF in manual transmissions, to show that, yes, there are some modern transmissions that use ATF.
Scott
Old Jun 4, 2011 | 10:11 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Not trying to inflame the debate, but concur that there are many manuals that use ATF including C5 and C6 Corvette Tremec manuals (my 02 Z06 uses an ATF for the six speed).
For the OP, this is AMSOIL's recommendation for your manual:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
Interestingly, same fluid I use in my diff.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jun 4, 2011 | 05:10 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Originally Posted by gkull
What we drained what red and thin. Any help would be great.
I went with what the poster originally said.
If you know anything about manual trannys how could you not hear of them using ATF?
I went with what the poster originally said too. That is why I spoke about a specific lubricant that I used in my car, that so happens to be a 90W gear oil and is colored red...like ATFs.
I know enough about manual trannys to know that a person should use what the manufacturer specifies. The last manual tranny car that I owned or worked on, prior to this vette, was a 1966 GTO that I bought in 1968. Pardon me.
Old Jun 4, 2011 | 05:33 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
Originally Posted by udornf4
Well, I be hand-dipped in horse do do. Learn something everyday!
first I thought WTH?
Old Jun 4, 2011 | 05:34 PM
...Roger...'s Avatar
...Roger...
Originally Posted by MelWff
I would love to see what it says in the back of an 81 owners manual concerning fluids, anybody have one?
It's actually in the front.
Old Jun 4, 2011 | 07:51 PM
tnovot's Avatar
tnovot
Exactly!!!
Terry
Old Jun 4, 2011 | 08:04 PM
jb78L-82's Avatar
jb78L-82
I refer to my original post on page 1:
"I was aware that some newer manual transmissions used automatic fluid like the 4+3 in the C4's as well as my 1988 Mustang 5.0 manual but have never seen it specified for older 4 speeds like the M22/M21/Borg Warner Super T-10's or in any C3. So are you saying that there are C3 manual transmission cars that had automatic fluid filled from the Factory?"
Like I said , never heard of a C3 manual transmission car ever having ATF fluid in the gear box!!!
Old Jun 5, 2011 | 01:49 AM
babbah's Avatar
babbah
Sta Lube GL-4 - My 44 year old Munice - never touched - still flawless operation - Running this in it since car was new.......
Old Jun 5, 2011 | 12:41 PM
69 Chevy's Avatar
69 Chevy
This is what I put in my '69 M21:
http://www.jegs.com/i/Richmond-Gear/...oductId=753497
Old Jun 5, 2011 | 05:44 PM
MelWff's Avatar
MelWff
Thank you Roger, so it's not ATF for this specific application.
Old Jun 5, 2011 | 09:06 PM
tnovot's Avatar
tnovot
"I was aware that some newer manual transmissions used automatic fluid like the 4+3 in the C4's as well as ---
Prior to my C3, I had an '84 with the 4+3 and to the best of my recollection, only the OD unit (basically a powerglide trans) used ATF but the 4 speed box itself used regular gear lube.
Terry
Old Jun 6, 2011 | 07:23 AM
jb78L-82's Avatar
jb78L-82
Terry
yes you are correct-not a good example from me! The C3 manuals never used ATF fluid as far as I know-just use a Gl 5 fluid and call it a day!
Old Jun 6, 2011 | 08:07 AM
  #33
...Roger...
Not according to the 81 Corvette shop manual,but that's not to say that ATF is not OK or even better in some aspects.
Is using ATF an upgrade ? Most of us certainly don't have a problem upgrading cam shafts,heads,carbs and etc.
I think fuel savings and probably more HP to the rear wheels would be important to some,but being safe with the old heavier lube might be for others.
Old Jun 6, 2011 | 08:25 AM
  #34
mrvette's Avatar
mrvette
Exactly, and my '72 here had a muncie in it, when I got it the thing shifted like a damn old school bus, hard and clunky even when hot, compared to newer cars.....so I changed fluid to 30W synthetic engine oil....it shifted like a new car then, slick as snot on a doorknob.... ran for two years that way, daily driven trip to Florida and back from Maryland, never a issue....
swapped in a OD auto for the ODrive....here, as speeds/distances are much greater than the DC region....
Old Jun 6, 2011 | 09:07 AM
  #35
jb78L-82's Avatar
jb78L-82
I had the same issues 20 years ago in my 4 speed-notchy when hot, down right stiff and resistant to shifting when cold, etc-changed to Amsoil gear oil and most recently to mobil 1 75W-90 full synthetic gear oil GL-5-never have had an issue since! My experience is that using a quality synthetic gear oil is all you need to do-no need for ATF/motor oils etc. I just changed this weekend the rear diff fluid on my 1994 mustang GT to mobil 1 75W-90 gear oil after 17 years (I know I should have done it much sooner!-26,000 miles on the car).
Old Jun 6, 2011 | 11:52 AM
  #36
...Roger...
I was told by a lubrication engineer that the unlike metals (non-ferrous and the ferrous)need a special lubricant so the braking action takes place in the synchro. Some lubes and maybe worn out or dirty lubes hinder the braking action needed to match gear speeds and shift smoothly.
Old Apr 20, 2014 | 10:49 PM
  #37
Mike 1959's Avatar
Mike 1959
1st Gear
Is it true that GL-5 fluid is not compatible with the synchros in a (old) 1959 T 10 manual transmission. That you must use GL-4 fluid. Because the shifting from 1st to 2nd was getting rough on my just rebuild transmission last year, I changed from a 90w GL-5 fluid to AC Delco Manual transmission fluid SAE 75W-85 G-4. The shifting got better last year, just got it back out this year and now I have a bearing whine when I down shift for braking. The AC Delco fluid is thin like ATF, not thick like the old 90w fluid.
To Manual transmission fluid??
Old Apr 22, 2014 | 12:30 AM
  #38
dugsgms74's Avatar
dugsgms74
Just my .02 worth. Beware of using GL-5 in older transmissions unless specified by the factory. It has a higher sulphur content that not only inhibits the sychros from working but also degrades yellow metal parts over time. I have a 06 pontiac solstice that asked for GL-4, I put in GL-5 and it didnt shift for ****, had to get the correct fluid from GM to fix the problem. I need to change the fluid in my 68 but am still looking for a local source for GL-4.
Old Apr 22, 2014 | 06:45 AM
  #39
Shovels and Vettes's Avatar
Shovels and Vettes
Notice the guy who called everyone a moron is silent now that the Service Manual was shown.
Yes, people make upgrades all across our cars, but the fact that someone on this forum says its a good idea in no way makes it so. This forum, like all forums, have so called experts, and usually they are the ones calling everyone else morons. Pretty typical.
Old Apr 22, 2014 | 07:21 AM
  #40
Marlin's Avatar
Marlin
Amazon has GL-4 75W-90 for manual trans.
Amazon Amazon
That's what I bought but there are a couple others as well.
