Manual transmission fluid??
Old Nov 1, 2023 | 06:52 PM
  #61
TO_Vette's Avatar
TO_Vette
I have a quick question regarding your previous response. If I understand correctly, you are using Mobil 1 75W-90 for your manual transmission. Are you also using the same oil for your rear end? If not, then what?
I'm in the process of replacing fluids in my stock 1981 vehicle, both for the manual 4-speed transmission and the rear end. After reading through various posts, it's challenging to determine the right choice. I would prefer to use synthetic oil, but it seems that might not be the best option. Additionally, finding conventional oil has proven to be a bit difficult.
Thank you in advance for your assistance.
Old Nov 1, 2023 | 07:03 PM
  #62
68post's Avatar
68post
Mobil 1 75w-90 is an excellent transmission fluid choice also. I've used it in the past and confirmed its use with the Allison engineer that did the durability testing on the 1983 SM465 transmission.
Your trans is no different in that regards. 75W-90 is equal to 30 weight engine oil at temperature.
Old Nov 1, 2023 | 07:17 PM
  #63
MelWff's Avatar
MelWff
Originally Posted by TO_Vette
No noises like that. To ask one more question, what do you run in the manual transmission?
Post 57 I stated both transmission and differential providing the bottle states for limited slip differentials.
Old Nov 1, 2023 | 07:34 PM
  #64
TO_Vette's Avatar
TO_Vette
Moble 1 Synthetic correct?
Also, do you use that in the Rear end Also?
Old Nov 1, 2023 | 07:38 PM
  #65
MelWff's Avatar
MelWff
I would only use a conventional gear oil suitable for limited slip differentials
Old Nov 2, 2023 | 09:21 AM
  #66
TO_Vette's Avatar
TO_Vette
Is Luqui Moly worth using and should I use it both the rear end and transmission?
Old Nov 2, 2023 | 09:48 AM
  #67
MelWff's Avatar
MelWff
Nooo! Where are you getting these ideas?? Use 75W90 conventional gear oil for both differential and transmission with 2 bottles of GM additive. Nothing else.
https://shop.valvolineglobal.com/pro...hoC3rEQAvD_BwE
Old Nov 2, 2023 | 09:57 AM
  #68
TO_Vette's Avatar
TO_Vette
So use additive in both the trans and the diff?
Old Nov 2, 2023 | 10:21 AM
  #69
MelWff's Avatar
MelWff
No, the additive is for the differential
