Side Yoke seals
Old Apr 22, 2002 | 04:19 PM
Koz
Guest
Posts: n/a
Default Side Yoke seals
Both my side yokes are leaking.. not dripping wet but wet. Is this a big job to replace the seals? I'm guessing I have to open up the differential to remove the yokes or can this be done from the outside? Is this a simple unbolt type of job or do I need special tools and shimms and etc... ? I'm leaning towards just leaving it BUT that feeling won't last too long and I'll want to fix it.. Any ideas?
Old Apr 22, 2002 | 04:22 PM
Wrecked82's Avatar
Wrecked82
Default Re: Side Yoke seals (Koz)
I am with you on this one. I have one side that is leaking. I have to fill up the differential once a year, 9 months. It is more than I can do, and it is more than a cheap repair, so I just refill. Probably this year I will have to have repaired, because dripping is gradually growing.
Old Apr 22, 2002 | 04:25 PM
norvalwilhelm's Avatar
norvalwilhelm
This is a big job. The rear end must come completely out then the cover can be removed. Once the rear end is on the bench it is no big deal and the yokes can be inspected to excess end wear but if you can live with a slight leak let it alone.
Old Apr 22, 2002 | 04:35 PM
Stingy74's Avatar
Stingy74
Default Re: Side Yoke seals (norvalwilhelm)
It is quite an in depth job. The diff does have to come down so you can remove the cover for access the the snap rings to remove the side yokes. And who knows what else it might need while your in there. The CR number (Chicago Rawhide) for the seals is 3820419.
Old Apr 22, 2002 | 04:36 PM
Wrecked82's Avatar
Wrecked82
This is a big job.
That's what I thought. So, a $5 bottle of differential fluid and a $5 bottle of limited slip once a year, and a dirty hour or so beats $$$!
Old Apr 22, 2002 | 04:40 PM
Stingy74's Avatar
Stingy74
Default Re: Side Yoke seals (Stingy74)
I just realized you car is an 80 with the Dana style diff. The part number for the seals I gave you are for an earlier car like my 74.
Old Apr 22, 2002 | 05:03 PM
Koz
Guest
Posts: n/a
That's what I thought. I have to clean off all the caked on crud and check the fluid level. My guess is I'm low! I figure SOMEDAY I'm going to pull the engine and tranny to do some work.. I figure I'll tackle the rear end at the same time.. Thanks! :cheers:
To Side Yoke seals
