tire size?
Old Jun 4, 2011 | 08:55 AM
mcmsmsc's Avatar
mcmsmsc
Default tire size?
i have 225-70 15 tires ok my 1977 vette. i get a little rub on occasion. what size would have been stock? i am looking at 215-70-15 bf goodrich or cooper. any thoughts. i want to keep a stock look.
Old Jun 4, 2011 | 09:04 AM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
my 80 has 225/70r-15's and I assume they are stock sized. Rubbing? have you checked yours shocks front & rear? and your front coils ? and your rear leaf spring? I have new front coils/shocks , there is at least a 2 inch clearance all around the tires.
Old Jun 4, 2011 | 09:24 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Find the source of the rub. 225s should not rub.
Old Jun 4, 2011 | 09:32 AM
flaco1801's Avatar
flaco1801
I had a lil rub too..i went to 225 60 in the front and left the 70s on the back...used one 70 as a spare... probably need new shocks on the front...
Old Jun 4, 2011 | 10:24 PM
mcmsmsc's Avatar
mcmsmsc
i will try to track down the source. it seems to happen more when in reverse and turning. it probably could use shocks all the way around.
Old Jun 5, 2011 | 12:56 AM
RIJVETTES's Avatar
RIJVETTES
Old Jun 5, 2011 | 01:12 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
A member here had 295 / 50 /15's on the front and back of his Vette, that was some time ago, can't remember who it was
Old Jun 5, 2011 | 08:28 AM
mcmsmsc's Avatar
mcmsmsc
found 1 spot it is the drivers front, front of wheel, lower part of wheel well on the inside. very light tire marks. a friend of mine has a 72 and he said he had the same problem and went to the 215-70-15 coopers.
To tire size?
