Gentleman; Is it worth the 750.00 to improve the geometry on the front end of my C3, by installing the Shark Bite Aluminum Control Arms??? I understand that it Changes caster, camber & roll center, Are these really things I would want to do?? Or are the Tubular A-Arms just as good?? Or should I just keep the stock A-arms?? After reading the ( Wheel alignment Rant ) I decided to ask these Questions.
Thanks, I Appreciate. Have a great day. Gene
I've also been looking at these upper A-Arms for awhile now. Speed Direct has a nice writeup about how they have changed the "Roll Center". I too am wondering if there is any noticable steering difference.
I have had them for a couple of years now. Worth while? For me yes but I am very critical of the handling. The main benefits (for me) are the increased castor angles available, a big plus with 18" wheels and the revised pick up points which eliminates bump steer.
Yes Sir; Maybe this is part of owning a C3, but; when I'm going 80, 85, on a six lane highway, I feel like I'm holding on for dear life. I had the frame checked when I started the rebuild. I have replaced all suspension components with all H. D. parts. I even replaced my Trailing Arms, Bilstein shocks, Spreader Bar, Strut rod kit w/heim joints, H.D. tie rod sleeves W/ locking nuts. I have added sway bars & taken them back off. The only thing I have not done is changed alignment shops. The shop has worked on all my cars for years, father to son. Have no problems with any of my other cars. Thanks for all your help, forum members. Have a great day. Gene
Gene,
Somethings wrong with the basic setup someplace. I can do 85 on the highway and let go of the wheel, everything is smooth without any wandering. My car is a 75 with all stock suspension, it's been rebuilt but everything is as the car was designed. No heavy duty stuff and all rubber bushings.
Obvious question but are you sure your alignment has been done properly?
Stimulate the economy all you want by buying those alloy A-arms but that's not going to correct your high speed steering problem. I'd say you need to upgrade your alignment specs to those recommended by VBP or Guildstrand...not just racing but the specs for everyday driving.
I installed the Steeroids power rack & pinion so used the specs recommended by them. But I also slotted my upper control arm shafts to gain more positive caster as described by forum member norvalwilhelm.
To all you guys who have cars that track nicely at high speeds, can you please share your front & rear alignment specs with us?
Thanks,
John
Hi John,
I would be happy to if I had them, I took mine to a Corvette shop near here and just had them do it. I assume they did it to GM spec but I actually don't know for sure. They never asked me what kind of driving I do or anything.
Bill
Yes Sir; Update, just came from the Frame shop. Right side upper A-arm took a good 1/2 of shims to bring it back to factory specs. I'm going out in the next half hour to the freeway to try it out. Thanks for all the help you guys gave me. Have a great day. Gene
Alignment, has been causing me the problem for at least the last three years. The Frame shop said; You should of brought this right back to us. They wouldn't even charge me, Said; They were very sorry for causing me the anguish. I can go right down the freeway, with hands off the wheel, at 85 MPH. Thanks to the Corvette Forum, another problem solved. I Appreciate. Gene
