Need speedo gear help!
Old Jun 7, 2011 | 01:40 PM
ndirishr1's Avatar
ndirishr1
Default Need speedo gear help!
I've changed my '68 roaster, 327/350hp, 4 speed manual's diff from a 3.36 to a 4.11. To correct the speedo I've been told that I need to get an orange gear, GM part #3860348.
1. Does this sound correct or how can I verify this?
2. Of course that part is discontinued, any suggestions where I can find one?
Old Jun 7, 2011 | 01:54 PM
BKbroiler's Avatar
BKbroiler
Zip sells the speedo gears. If your speedo was right before then you want a gear with 4.11/3.36 = 1.22 times the number of teeth on the orginal gear. The bigger gear will slow the speedo reading down. Select it by the number of teeth, not the color.
Old Jun 7, 2011 | 02:05 PM
qtlow's Avatar
qtlow
Default Fwiw
Here's a site that may be of some help to you.
http://www.thegearbox.org/catalog/it...82/3547889.htm
To Need speedo gear help!
