no power
Old Jun 7, 2011 | 11:50 AM
54dave's Avatar
54dave
Navigator
Default no power
:Hi Everyone , new guy here ....Have a 77 vette that my wife and I bought about 5 years ago and we're having a great time with it. Last weekend I went to start it and nothing no power at all. I do have a quick disconnect for batt , and when I first tried I had lights but when turning the key lights went out . checked batt and it's got juice .next pulled starter and it's good , the last thing I did was put in a new starter switch , still nothing ... any ideas?
Old Jun 7, 2011 | 11:56 AM
MelWff's Avatar
MelWff
how did you check battery, did you put it on a charger and then do a load test?
Old Jun 7, 2011 | 11:57 AM
qwank's Avatar
qwank
your battery could have 12 volts but 0 amps
Old Jun 7, 2011 | 12:04 PM
54dave's Avatar
54dave
Navigator
Pulled batt and had a parts store check it , and it was fully charged
Old Jun 7, 2011 | 12:05 PM
54dave's Avatar
54dave
Navigator
yea I took batt over to local part store and they said it was good ...thought it might be a bad pos batt cable ...
Old Jun 7, 2011 | 12:07 PM
7T1vette's Avatar
7T1vette
Neutral start switch failure; starter solenoid failure; ignition key/fuse/wiring problem; transmission interlock system problem; battery cable/connection problem; dumb auto parts guy doesn't know how to "load test" a battery.
Old Jun 7, 2011 | 03:03 PM
54dave's Avatar
54dave
Navigator
Will take batt and have them " load test " and remove the starter and have them test the solenoid . with that said is there an inline fuse near the starter end of the batt cable also ..? thanks guys you've given me some other areas to think about if this dosn't work ..oh also checked the fuses at the fuse box up at the top of firewall , and everything is ok ..
Old Jun 7, 2011 | 03:07 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Ground strap...try putting in neutral......
To no power
