73 Radiator Removal
Old Jun 8, 2011 | 12:22 AM
C2C6Z06's Avatar
C2C6Z06
St. Jude Donor '08-'09-'11-'12
Default 73 Radiator Removal
OK, I have been working on getting the rad out on this car for an hour! Removed the rad hoses, two uppper side mounting brackets, fan and clutch, lower shroud nuts, upper center bracket, and just cannot get the dang thing out.
The shop manual says to lay the shroud back on the fan and lift the radiator out - that ain't happening because the shroud hits the front upper a arm bushing bolts. I manage to squeeze the rad up between the rad support and shroud but the lower hose fitting hits the right side a arm assy....
I'm about ready to take the whole rad support out and pull it that way but I'm afraid I will be taking away support for the body...
Any ideas?
Old Jun 8, 2011 | 02:01 AM
RickyBerg's Avatar
RickyBerg
I usally first removed the cooling fan, then removed the shroud.
Then you are free to remove the radiator.
Old Jun 8, 2011 | 08:12 AM
calif phil's Avatar
calif phil
On my 73 it will not come out without more room. You can gain more room by removing the right side upper A-arm, that is how I did mine. You can also loosen the radiator core support but to me that seemed like a lot more work and I dont like the idea of the front end not supported or the fenders cracking like I have read about so I opted for the A-arm removal which is quite easy. The whole job is a PIA and you would have thought they could have made it a bit easier for us.
Old Jun 8, 2011 | 08:19 AM
Timsride's Avatar
Timsride
On my 73 I had to loosen the rad saddle on passenger side then have my son pull towards front of car to get it in. I had to rotate it sideways with the shroud attached and no fan on motor. What a PITA for such a relatively small job. If you can I would try installing lower rad hose to rad as when its in its even a bigger PITA. Good luck.
Old Jun 8, 2011 | 09:07 AM
Kneel 8250's Avatar
Kneel 8250
St. Jude Donor '11-'12
GM workshop manual says to remove the right side upper A arm.
Kneel.
Old Jun 8, 2011 | 09:35 AM
C2C6Z06's Avatar
C2C6Z06
Kneel.
I guess that is the one book I don't have!
Thanks all for the reassurance that I'm not a complete mechanical dud!
What a PITA for a simple rad removal!!
Old Jun 8, 2011 | 09:56 AM
Kneel 8250's Avatar
Kneel 8250
I am doing a restoration on the 73 we have and rebuilt the front suspension, rebuilt rear suspension, brakes, oops, rebuilt rear suspension again as you need room to place equipment that is not there with Trailing arms together. Radiator goes in and front end has to come apart to fit it.
Its been fun and games up till now. Work is progressing slowly tho.
Hang in there and it will all come together for you.
Kneel.
Old Jun 8, 2011 | 01:47 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
That's exactly how I get mine out.
Kneel.
Wow! I did something by the book and didn't even know it.
Old Jun 8, 2011 | 02:32 PM
76GlassY's Avatar
76GlassY
Default Rad Removal
Don't know how much different the 73 is from a 76 shroud but changing the cam on the 76, I unbolted the rad support (3 bolts from inside each fender well ) and pulled the whole support foward until I could pull the shroud up and out. It was still a pain to get out but I knew it wasn't comming out without moving the support foward or messing with the suspension, which I realy didn't want to do. Didn't seem like the support was holding the front of the car together, as I've heard, and never had a problem with fender alignment or cracking afterward. Never even had to undo the A/C condenser, just unbolted it from the support. Wound up replacing the support anyway due to rusted out bottom. New one went in with no problems and no shims, which was how it came out.
Jim
Old Jun 9, 2011 | 04:15 PM
RickyBerg's Avatar
RickyBerg
This is not correct.. When i removed my radiator the right hand A-arm was already removed..
Sorry about that.
//Ricky.
Old Jun 9, 2011 | 04:40 PM
C2C6Z06's Avatar
C2C6Z06
Again, thank all of you for your guidance and experiences. It was simple to remove the upper a arm. Once that was done (with the fan gone already)- the radiator slipped right out!!
To 73 Radiator Removal
