A.I.R. System
Old Jun 9, 2011 | 08:54 PM
arkus's Avatar
arkus
Default A.I.R. System
In general , will your 69 corvette run better with the smog pump in tact ?
Everything else being original. Will not having a smog pump effect the vacuum system , wiper door , headlights etc..
Old Jun 9, 2011 | 09:59 PM
63split63's Avatar
63split63
The smog pump pumps air into the exhaust ports . If you take it off you won't notice any difference . Back in the day most people took them off rather than fixing them if there was a problem .
Bill
Old Jun 9, 2011 | 10:03 PM
Timsride's Avatar
Timsride
The only thing the air pump does is inject air into the manifolds so unburnt fuel can burn away thus decreasing emissions.
Old Jun 9, 2011 | 10:36 PM
arkus's Avatar
arkus
were there any vacuum hoses connected to the pump ?
Old Jun 10, 2011 | 12:16 AM
Mike Ward's Avatar
Mike Ward
Not to the pump but to the diverter valve that's attached to the pump. The valve stops/starts the flow of air from the pump in accordance with manifold vacuum.
Old Jun 10, 2011 | 12:26 AM
arkus's Avatar
arkus
Would this help the vacuum system run better ?
Old Jun 10, 2011 | 12:33 AM
Mike Ward's Avatar
Mike Ward
No, assuming that the diverter valve is operating properly and does not have a punctured diaphragm.
To A.I.R. System
