Timing or Carb??
Old May 14, 2011 | 01:34 PM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
Default Timing or Carb??
This morning I was out and about. Car started fine, idled fine and ran fine at part throttle. My problem occoured when I was getting on the interstate pulling a hill on the on ramp. As i layed into it, I noticed it was not accelerating smoothly. Gave it more throttle and it got worse. Popping and backfiring and pretty much running like ****!!!
Let off and cruised up on the highway at part throttle and it ran fine. Now we all know that there is no use in having a Corvette if you can't stand on the go pedal, so my search for the problem will begin tomorrow.
I am running a zz454 with a Holley 850/mech sec carb. My dist. is a HUI electronic tach drive dist. Not sure what I have for initial timing or what it advances to, but I know the vac advance is disconnected and always has been.
Any ideas where to start???
Old May 14, 2011 | 01:55 PM
jnb5101's Avatar
jnb5101
as the late, great unperson lars has said many times( if i may freely quote) 99% of carb problems are caused by the distributor.
Old May 14, 2011 | 02:01 PM
birdsmith's Avatar
birdsmith
First thing I'd suspect would be loose distributor hold-down bracket. Sounds like the timing retarded...
Old May 14, 2011 | 09:03 PM
Timsride's Avatar
Timsride
Not to send You into a tail spin. Has this car been driven regularly? Has something just been recently changed? Even something as simple as a gas fill up could cause this. If nothing was changed I would question the distributor. But also check linkages on carb for binding or missing.
Old May 14, 2011 | 09:38 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
It sounds to me like fuel starvation. Is it only stumbling when you are asking for high fuel delivery, that is what I got from your post. How long since fuel filters were checked and screen in tank, how about the fuel pump?
Old May 15, 2011 | 07:34 AM
DIP51's Avatar
DIP51
Nothing has been changed and it really hasn't been driven regularly yet this year. It does seem to be a WOT issue, but it starts to rear it's ugly head when I start laying into it. The filter and pump were new when the engine was installed about 6k miles ago.
I will check the hold down bracket first, as this is the easiest place to start and go from there.
Old May 15, 2011 | 08:48 AM
boltnut's Avatar
boltnut
Yep, time for a shakedown after sitting. Look for loose connections, loose bolts, bad hoses, leaks, ect. Get some fresh gas in there and maybe even clean out the carb.....could even have varmits in your rigging....JMO
Old May 15, 2011 | 10:29 AM
7T1vette's Avatar
7T1vette
Run a can of SeaFoam through it. You can get some accumulation of 'varnish', etc. over a 6K mile stretch. It will clean up the carb/engine. Also, if you still have a points ignition system, swap out the condenser. When that starts to go bad, performance 'sucks'.
Old May 15, 2011 | 12:22 PM
Vette5.5's Avatar
Vette5.5
Could be fuel starvation, but the back firing sound's more like a timing issue, and hopefully the timing chain didn't jump a few teeth. As for mentioning Lar's tune, last I heard he was in fine health. Believe there were some disagreement's on the forum, and no longer post's.
Old May 15, 2011 | 12:50 PM
BPHORSEGUY's Avatar
BPHORSEGUY
[QUOTE=Vette5.5;1577620872]Could be fuel starvation, but the back firing sound's more like a timing issue, and hopefully the timing chain didn't jump a few teeth. As for mentioning Lar's tune, last I heard he was in fine health. Believe there were some disagreement's on the forum, and no longer post's.[/QUOT
Lars is active in other areas, I also recommend trying seafoam, it's cheap and certainly won't hurt though I doubt it will cure this problem completely!
Old May 16, 2011 | 11:00 AM
Rich's'78's Avatar
Rich's'78
Originally Posted by BPHORSEGUY
It sounds to me like fuel starvation. Is it only stumbling when you are asking for high fuel delivery,:
Simple thing to check is is the gas tank cap venting?
Old May 16, 2011 | 04:07 PM
Timsride's Avatar
Timsride
My 70 camaro did the same thing a couple years ago. It was so bad it blew the valve cover gasket out. It turned out to be old gas. I ran through a couple of tanks and the problem went away.
Old May 16, 2011 | 06:23 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
also, check to see that the electric choke is working and opening the front baffles 100 % after 2 minutes of run time.
Old May 16, 2011 | 08:32 PM
Saubrenner's Avatar
Saubrenner
I sure like that Lars quote. I've seen lot's of guys spend money all the way up to buying a new carb and then finally admitting "well I did change the plug wires, but that couldn't be it".
I'm certainly not implying any of that with you, I just love the quote.
Old May 16, 2011 | 09:38 PM
SmokinBBC's Avatar
SmokinBBC
I am running a zz454 with a Holley 850/mech sec carb. My dist. is a HUI electronic tach drive dist. Not sure what I have for initial timing or what it advances to, but I know the vac advance is disconnected and always has been.Any ideas where to start???
Is the dist a DUI?
Old May 17, 2011 | 10:11 AM
DIP51's Avatar
DIP51
Originally Posted by SmokinBBC
Is the dist a DUI?
Yup...DUI, not HUI. Guess I had a brainfart or was trying to type too fast!!!
Old May 17, 2011 | 12:56 PM
Rich's'78's Avatar
Rich's'78
I first read that in the early '80s, by the great Smoky Yunick. It's any part of the ignition system, before carburation.
To Timing or Carb??
Old May 18, 2011 | 07:39 PM
SmokinBBC's Avatar
SmokinBBC
DUI usually stencils the dist. specs under the base if it was custom curved for an application.
Why do you have the vac advance disconnected?
Old May 19, 2011 | 11:48 AM
DIP51's Avatar
DIP51
It always has been disconnected. When we installed the crate motor it was set up that way by a friend of mine. I have read all the flame posts that say you need it, but it was running fine last year. Sadly, he died this winter after a short battle with cancer, so I no longer have his assitance, that is why I am looking for help here. I never messed with the technical stuff (carb or dist tuning), I was always the nuts and bolts guy. Never had any problems with removal or install of components, just never messed with the "finesse" stuff!!! I guess it is time to jump in feet first!!
I am contemplating taking the dist. out and sending it to DUI and have them custom curve it for my application, with a functional vac can.
Has anyone had first hand experience dealing with DUI??
Old May 19, 2011 | 06:44 PM
SmokinBBC's Avatar
SmokinBBC
DUI employees are good people. If you need help, just call them.
So I gather that the specs are not on the dist? If you can get a mirror, look under the base. Another way to tell if it was custom is to look at the advance springs. They will paint the spring that goes with the accopanying advance weight.
Here is a link to a super Chevy article with the zz454 specs. They produced a nice 502hp with 34 degrees total mechanical timing(initial 12 plus 22 in the dist) and a 770CFM Holley and headers.
http://www.superchevy.com/technical/...t_results.html
You already know this, but if you are going to drive it mostly on the street, the most efficient set up will include the vacuum advance.
Good luck.
