Ecm 1981
Old Jun 9, 2011 | 10:43 PM
Mark Hawkins's Avatar
Mark Hawkins
Default Ecm 1981
How long do this things last? I'm assuming mine is original. I have a code 14 which my GM Service manuel says to read also code 21. In Code 21 it refences that i may need to replace the ECM. Okay say i do replace it. Now, there are "Chip" options. I'm using the car as a weekend joy ride. Something to drive and have fun. Thanks in advance.
Old Jun 10, 2011 | 03:20 AM
RC81's Avatar
RC81
I have replaced mine but it turned out I didnt need to - my original was working fine. If you do replace yours you need to switch over your chip to the new one. These chips are hard to find - the only aftermarket one I could find was made by Hypertech.
Old Jun 10, 2011 | 09:50 AM
jr105's Avatar
jr105
I just replaced mine with a remanufactured AC/Delco ECM that I purchased from RockAuto. Mine had a problem with the ignition advance, and would not light the check engine light so I couldn't read codes. I used the chip out of the old unit and it worked fine.
Old Jun 10, 2011 | 11:57 AM
81pilot's Avatar
81pilot
Mine lasted about 6 months after I bought mine....thats when I unhooked it for good....
Old Jun 10, 2011 | 05:04 PM
terry82's Avatar
terry82
.have you tryed clearing you code?is there a problem with your car other than you have a light on?
Old Jun 10, 2011 | 05:31 PM
Mark Hawkins
what made you think you needed to replace your ECM?
Old Jun 10, 2011 | 05:34 PM
Mark Hawkins
hey, i've cleared the codes. 14 came back. Service manual says to see code 21 too. This states that I might have a short. Howver I've broken my left arm so it has kept me away from tinkering with the car.
Old Jun 10, 2011 | 05:35 PM
Mark Hawkins
what year carb & dizzy did you replace your with?
thanks.
Old Jun 10, 2011 | 05:42 PM
Mark Hawkins
thanks. how long had you owned the car when you replaced the ECM?
Old Jun 10, 2011 | 09:30 PM
jr105's Avatar
jr105
I've had it for 3 yrs. During that time it never quite ran right. I chased sensors and worked on the carb during that time and could never get it the way I thought it should run. When I changed the ECM it ran like a different car.
Old Jun 11, 2011 | 04:20 AM
RC81's Avatar
RC81
I was having problems with my check engine light coming on at idle and not setting a code. Turned out my carbs throttle shaft was worn and throwing off the mixture at idle. Ended up getting a rebuilt carb then learned how to set it and adjust it. No problems since and put my original ECM back in. Now I have a spare!
To Ecm 1981
