82 Fuel pump/relay/pressure problems??
Old Jun 13, 2011 | 07:03 PM
wrc69v's Avatar
wrc69v
Default 82 Fuel pump/relay/pressure problems??
Should the engine stay running if the oil pressure switch is unplugged? I think it should start but should it stay running with no signal form oil pressure switch?
I have the oil pressure switch unplugged and engine cranks and stays running? Is this right?
Im trying to isolate a fuel pump/relay/oil pressure switch problem. Its a challenge!
Old Jun 13, 2011 | 08:05 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I'm pretty sure all the oil pressure switch does is send the signal to the gauge so yes the car would continue to run.
