Do you really have to have stainless steel bore liners to use the o-ring seal pistons? I bought rebuilt calipers from napa before I new any better, and I would like to install o-ring seal pistons in them. It will most likely be temporary, for a year or two, till I can upgrade to the Willwood aluminum calipers. Thanks,
If you use dot 5 brake fluid throughout the system the iron calipers will last a long time since dot 5 does not take up moisture and I can't see why the o-rings would not work better than the lip seals.
QUOTE=scottyp99;1577922681]Do you really have to have stainless steel bore liners to use the o-ring seal pistons? I bought rebuilt calipers from napa before I new any better, and I would like to install o-ring seal pistons in them. It will most likely be temporary, for a year or two, till I can upgrade to the Willwood aluminum calipers. Thanks,
Scott
[/QUOTE]
bought my o-ring setup from the original designer (ZTI) before he sold to a brake outfit. He told me no need to SS sleeve my bores if they could be honed . Had to be in the early 90's and I still have no issued . (Dot 5 fluid)
OK, turns out there is a liner in the bores, I didn't see it because I was expecting something thicker. One of the liners had just barely crept out of the bore, loosening the dust cover, I tapped it back in, I hope it stays put. The O-ring seals made the job much easier than fussing around with the lip seals. The pistons have a much closer clearance than the old lip seal pistons, too. I am hoping for good results. Installed them today before work, will be bleeding them tomorrow, I'll let ya know how it goes.
Scott
EHHHH....U got a issue there, that brake fluid WILL work it's way around that loose liner....you need get another caliper....
O ring seal calipers are actually for floating calipers like the 84 Vettes and later......Lip seal calipers are those used from 65 through 83 Vettes that are not a floating style and instead rigid mounted......but whatever works for you....neither style are immune from rust forming with regular fluids damaging the seals especially the cars are not used on a regular basis.....high humidity areas could probably contribute to moisture too
Every opposed piston solid mount caliper on the market uses either o-rings or square o-rings and have for decades. Only the Corvette calipers use the lip seals.
