Neutral safety switch
Old Jun 20, 2011 | 08:40 AM
jnanderson61's Avatar
jnanderson61
5th Gear
Default Neutral safety switch
After rewiring my vette, it would not start in park, so I purchased a new neutral safety switch. It worked fine, except the backup lights remained on in every gear (did not happen with old switch). I returned the defective switch for a replacement. Upon installing the replacement, it started in park, however, when I set forth to adjust the position for neutral, it turned the engine over while ignition 'on' but not engaged. I quickly moved gear back to park and turned off engine. But, not it will not start at all. I checked all fuses and links, and all seems as it should be. However, when I jump relay it just clicks. It seems I cannot jump the starter selenoid either. In addition, the back up lights do not work at all. Any suggestions? Yes, placed full charge on battery. Thanks.
Old Jun 20, 2011 | 10:14 PM
7T1vette's Avatar
7T1vette
You really shouldn't have battery power hooked up when trying to adjust the NSS. You should use an ohmeter to detect when the NSS makes contact and assure that this only happens in Park and Neutral. You can also use the ohmeter to detect when the back-up light circuit is 'made' (should be in Reverse, only). Don't reconnect the battery until the NSS is operating properly.
Old Jun 21, 2011 | 11:38 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
ok alot going on there...what year car?..some thing is not wired properly....the neutral safety switch allows the power to flow from the ignition switch (ign sw) in the "crank" position to the solenoid and it passes through the switch. it should never allow the engine to crank without the ign sw turned to crank. the back up light portion is just a fine tuning adjustment of the switch. my guess is the igniton key switch has loose wiring and some how the wire from the "crank" position is touching the hot wire in the switch. at least thats where i would start. i suppose the other logical end would be to see if the wiring at the solenoid is correct.
Old Jun 21, 2011 | 12:43 PM
jnanderson61
5th Gear
Thanks Bob. It is a 74 with 350 and automatic. This is the second swittch I installed with problems. However, only found one vendor who carried item. Original switch worked with exception of park, so rewire was ok. I am going to check ignition switch as you suggested. Thanks again.
Old Jun 21, 2011 | 03:02 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
a switch, is a switch, it does not care about park position.
you need to test each switch with an ohm-meter to verify it works properly.
after that it is either your wiring, or a mechanical position setup of the switch.
get a basic ohm-meter, and learn to use it.
Old Jun 21, 2011 | 03:04 PM
bobs77vet's Avatar
bobs77vet
ok for testing purposes lets put a jumper in between the connections that push on to the Neutral safety switch.....this will just be a straight piece of wire stuck into the two female spade terminals....nothing should happen when the car is turned off...nothing should happen when the car is turned on....only when you turn the ignition switch to crank should the solenoid be energized. this eliminates the switch completely and will give you a sense of whats going on...how while you are there just make yourself and actual jumper that does the same thing and throw that in your box behind the pass seat and you now have an emergency by pass jumper in the event you ever get stuck.
you could also use a 12volt test light to one of the two leads and see
what happens when you turn the ignition switch, one will be hot in the crank position only and the other should never be hot
Old Jun 21, 2011 | 04:05 PM
jnanderson61
5th Gear
Thanks. I have reinstalled old switch and tested with light. The ignition 'surge' current is coming through, but still no ignition. I even took out starter to bench test and make sure solenoid on starter ok. All good. A bit of a mystery. I checked ignition switch and all test ok. Running out of options in the ignition line, but will keep checking. Traced current all the way through. Starter relay was replaced already, but should be irrelevant as I tried shorting across poles to bypass with no success. As to other response...ohm meter...what's that..HA!
Old Jun 21, 2011 | 04:59 PM
noonie's Avatar
noonie
Make sure you bypassed the proper wires at the relay.
Here is a simple permanent bypass.
The complete circuit is pretty simple,
ignition start terminal>neutral switch>start relay> purple wire on solenoid.
On original neutral switches, I have soldered the crimped oem connections and solved start wire issues, but be carefull not to melt the plastic.
Old Jun 21, 2011 | 09:30 PM
bobs77vet's Avatar
bobs77vet
interesting...about the only thats left is a bad ground for the starter. you said you traced the line to the starter so that when you turn the ignition switch to crank you are seeing 12 volts at the solenoid? if so clean all the grounds that go from the engine to the frame horn by the fuel pump. perhaps you have a ground that is just good enough for a volt meter or a test light but will not support the high draw of the cranking starter. does you starter have a ground bracket at the end towards the front of the car that mounts to the engine? if so clean all of those areas.
edit: i think you should clean all your grounds especially from the battery to the frame and also make sure your battery is fully charged
Old Jun 21, 2011 | 09:33 PM
...Roger...'s Avatar
...Roger...
Old Jun 23, 2011 | 04:01 PM
kiretunk's Avatar
kiretunk
I've had same problems before. First thing I did was to rebuild my auto tranny, because I thought it was that which made the noise. Well, it actually was my starter that was cranking in Drive....
My solution:
Cut the purple short wire going from one contact to the other on the NSS. I think 74-75 have this wire, but I don't know why its there. But it worked for me.
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Good luck
To Neutral safety switch
