Muncie Noise in First
Old Jun 21, 2011 | 07:35 AM
63split63's Avatar
63split63
Default Muncie Noise in First
My Muncie (71 M-22) makes a noise in first gear that sounds like there is a tooth missing. It dosen't always make the noise , most of the time it is there . If I pull the shifter back a little before I let out the clutch it sometimes is gone . I had the tranny out and inspected and could see nothing wrong internally . I know that M22s are noisey !
Anyone care to diagnose this for me?
Thanks Bill
Old Jun 21, 2011 | 08:12 AM
...Roger...'s Avatar
...Roger...
I'd have to get my gear head on , but off the top "pulling the shifter back a little" will move the slider forward. The slider has a bevel for clearance. I'll have to think about it for a min.
Old Jun 21, 2011 | 09:24 PM
63split63's Avatar
63split63
Thanks Roger, anyone else have an idea ?
Old Jun 21, 2011 | 09:54 PM
ZZ71S's Avatar
ZZ71S
http://www.5speeds.com/muncie.htm
Talk to these guys
Old Jun 21, 2011 | 10:26 PM
...Roger...
History ? Is this a new problem from a tranny that had been operating normally ?
Tranny been apart recently ? If so might someone have flipped the sliders ? Are both beveled ?
Old Jul 10, 2011 | 04:36 PM
DrainSurgeon77's Avatar
DrainSurgeon77
The reverse idler in the main case is very close to the 1-2 slider when 1st gear is engaged, and I have had noise complaints and seen wear marks on the idler gear from the 1-2 slider, that could be your noise...
About 10 years age I started clearancing all the reverse idlers on all the Muncie's I rebuild...
Hope this helps... Crash
To Muncie Noise in First
