Interesting Electrical problem
Old Jun 22, 2011 | 08:28 AM
ja1724's Avatar
ja1724
St. Jude Donor '12
Default Interesting Electrical problem
Last night I was testing something with the car running but the headlights were off. Whenever I pressed the brake pedal the all the dash/cluster lamps would illuminate. It did this about 10 times then wouldn't do it anymore. Anyone ever have this happen to them? Where should I begin to look - the brake light socket?
Thanks.
Old Jun 22, 2011 | 08:51 AM
black75's Avatar
black75
Sounds like a ground problem to me for the dash harness. The ground for this is located on the drivers side door post above the kick panel. It is a black ~14 ga. wire with a round single screw crimp connector. I always check the grounds first whenever i have a weird one like that. Good luck.
