Differential Oil Level
Old Apr 24, 2002 | 12:02 AM
Engage's Avatar
Engage
Default Differential Oil Level
Where is the plug to check the diff oil level on an 81?
Is it that hard to get at (like everything else) plug at the upper rear of the diff? :cry
Old Apr 24, 2002 | 12:22 AM
LATNC3's Avatar
LATNC3
Default Re: Differential Oil Level (Barry)
there is no check valve.....there is only a fill hole and a drain plug. you should be able to see the drain plug as soon as you go under the car. you have the cast aluminium rearend right?
Rod :cool:
