Tire Size
Old Jun 22, 2011 | 04:57 PM
hadams's Avatar
hadams
Default Tire Size
I’m currently running old Dunlop Qualifier 225/70/15s on post 76 aluminum wheels. I need to replace the tires and have seen many C-3s with 235/60/15 BF Goodrich ties on the front and 245/60/15s on the rear with OEM 15X8 wheels.
Anyone know if there are any significant tire rub issues before I go and spend the money?
Old Jun 22, 2011 | 06:06 PM
KevinK's Avatar
KevinK
245 might be a bit fat on that wheel...but the radius is smaller, thus creating more room. I'd stick with 235 front and back, though.
Old Jun 22, 2011 | 06:11 PM
scottyp99's Avatar
scottyp99
A very popular optional tire size from the factory on the later C3's was 255/60/15. I wouldn't worry about a shorter tire with less tread width.
Scott
Old Jun 22, 2011 | 06:20 PM
msandym's Avatar
msandym
Default tire si
on my 71 , I have 235 60 15 T/A's all around, front rubs on extreme turns, otherwise no problem . I'de like to replace rears with 245 or 255 eventually
Old Jun 22, 2011 | 07:27 PM
scottyp99's Avatar
scottyp99
What year is your 'vette? The later cars had more room in the fenderwells, I think. I run 255/60/15 on all four corners on my '80, no problems.
Scott
Old Jun 22, 2011 | 08:03 PM
hadams's Avatar
hadams
Well I'm a 75
I eventually want to go with American Racing Torque Thrusts 15x8.5 Boltpattern 5x4.75 (5x120.65) Offset -25 Hub Bore 83.06 Partnumber VN1055861. Corvette Central sells these as a C-3 direct fit.
I still need to replace the old Dunlops from 1993. They are hard and beginning to split in the centers.
I have seen many many Corvettes with the 235 in front and 245 in back. they are typically 71-71 and even earlier though.
Old Jun 22, 2011 | 08:10 PM
68sbcoupe's Avatar
68sbcoupe
Originally Posted by hadams
Well I'm a 75
My current 68 has 235 front, 245 rear. Last one had had 245 front, 275 (60) rears.
Wheel backspacing is critical for clearance. if you keel it 4" or less, you can go as large as my old car.
Old Jun 23, 2011 | 06:24 AM
dgood's Avatar
dgood
I have 255 60r 15s in the rear and 2345 60r 15s in the front of my 79. No rubbing and I do have a fiberglass spring in the rear.
Old Jun 23, 2011 | 10:57 AM
crazyeight's Avatar
crazyeight
I have a '75 with 255/60-15's on all 4 wheels. The fronts rub when I cut the steering wheel all the way, say when I'm backing out of my garage. I pulled a rear tire recently and there were slight rub marks higher up on the fender well, so I'm guessing the rear rubs when the car bottoms out.
Old Jun 23, 2011 | 11:14 AM
7t9l82's Avatar
7t9l82
my 79 with factory aluminum wheels run 255-60-15 on the front and 275-60-15 on the rear. no issues at all
Old Jun 23, 2011 | 02:22 PM
dntoearthman's Avatar
dntoearthman
I'd like to see a pic of the rears, bet it fills up the rear nicely
Old Jun 23, 2011 | 02:35 PM
Peeps9823's Avatar
Peeps9823
I have a 74. Just put 225/70/15 BF Goodrich T/A's on stock rims...proper clearance....they look sweet! Not the best picture, but I'll try to get a couple others posted.
Old Jun 23, 2011 | 03:59 PM
scottyp99's Avatar
scottyp99
The nice thing about the 255/60/15 tires is that they are about the same diameter (about 1/3rd of an inch shorter) as the 225/70/15 tires, so they fill up the fender opening properly, and there is very little speedometer inaccuracy. A 235/60/15 will have a smaller diameter than a 255/60/15. I'm not sure if it would be noticeable to the naked eye, but here are some numbers I got from a pretty cool calculator online.
http://www.1010tires.com/TireSizeCal...?action=submit
225/70/15 diameter:27.40 in
255/60/15 diameter:27.04 in % difference:1.32%
235/60/15 diameter:26.10 in % difference:4.75%
Scott
Old Jun 23, 2011 | 04:18 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
IMCO 245/60's (26.57") and 255/60's are about the two best sizes from which to choose for a 15x8 rim.
Old Jun 23, 2011 | 09:55 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
295's on stock '80 rims are a good fit too
Old Jun 24, 2011 | 05:38 AM
PowdercoatBill's Avatar
PowdercoatBill
I run a 255-60-15 in the front, 275-60-15 in the rear on stock 8in. rims on my 77. No issues!
To Tire Size
