Power Window headache
Old Jun 24, 2011 | 12:38 PM
peacock47's Avatar
peacock47
2nd Gear
Default Power Window headache
UNCLE............ I need some help with my power windows. I have a '76 and the power windows do not work in either direction. I have a fully charged battery and even with the car running, they still do not work. I have check the wiring to make sure there is no breaks in them and they all ring out good. I have checked the fuse (30A rectangle, #2 down from left of fuse panel) and installed a new power window relay. When I install a jumper-wire, they work......... I am about to rewire the whole power window circuit because I am so p*ssed off........PLEASE HELP
Old Jun 24, 2011 | 12:57 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
new cheap switches ? , use a volt meter to verify switches work...
don't have one, use a light bulb for basic switch test.
Old Jun 24, 2011 | 02:12 PM
peacock47's Avatar
peacock47
2nd Gear
I just checked the switches and they all are good. So, switches are good, wiring is good and fuses are good. I did find out that the rear defrost is not working. Is it possible that those two are linked somewhere???????
Old Jun 24, 2011 | 02:56 PM
wajulia's Avatar
wajulia
If either switch is broken or corroded, neither window will work. If the motors work as you say, I would replace the switches.
Old Jun 24, 2011 | 03:23 PM
...Roger...'s Avatar
...Roger...
Plug the pink/black wire back into the IGN tap in the fuse box,you probably kicked it out with your foot.
Old Jun 24, 2011 | 06:23 PM
69Vett's Avatar
69Vett
if you test the motor, and the switches, that leaves incoming power /fuse.
and the relay. to troublshoot start at the power source, veirify power on harness and follow all the way thru switches to the motor. if everything is wired properly.
only 1 thing left, Gnd to motors, do not assume they are grounded.
run a solid #10 GND. wire from each motor to verified Birdcage gnd.
common problem of poor gnd to window motors.
you do have the key on right ?
To Power Window headache
