Holly pro-jection 4 question
Old Jun 25, 2011 | 11:26 AM
MasterDave's Avatar
MasterDave
Moderator
Default Holly pro-jection 4 question
Have a chance to pick up a new in the box system pretty cheap. Flows 900 cfm and is a complete system. I will have to install a fuel return line but could put it in the overflow tube in the filler neck. Does anyone here know of any issues or is it an OK system? Thanks
Old Jun 25, 2011 | 11:24 PM
MasterDave's Avatar
MasterDave
Moderator
Ooooo.....
Old Jun 26, 2011 | 05:53 AM
Golden's Avatar
Golden
Does it come with the Commander or Avenger ECU?
Old Jun 26, 2011 | 10:29 AM
MasterDave's Avatar
MasterDave
Moderator
Thanks for commenting. I just went out and looked over the ECU and there is nowhere on it where it states which it is. I will say that even though this unit has never been removed from the box, it is a number of years old...maybe 15. Thanks.
Old Jun 26, 2011 | 10:53 AM
Golden's Avatar
Golden
As far as I know (which isn't much), about the after-market Holley EFI systems, the earliest was the Commander 950, but that's only around 5-6 years old.
I don't know if Holley have ever made an OE system or a complete/partial replacement for the Crossfire system?
Old Jun 26, 2011 | 11:13 AM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
The earliest Holley TBI systems were "screwdriver boxes." They had a series of ***** for adjustment and were not laptop programmable. They did not work that well, even then.
Old Jun 26, 2011 | 12:44 PM
carriljc's Avatar
carriljc
Default don't bother ....
I have a holley pro-jection in a box in the garage. Actually worked "ok", 670 CFM, but it was analog, and there is a lot better stuff nowadays.
Old Jun 26, 2011 | 12:48 PM
1Fordman's Avatar
1Fordman
I had one years ago the screwdriver tune-able one. It worked but was not fun to set up. The lap top tune-able one is light years better.
Once I got it closely dialed in it was actually a good system.
Old Jun 26, 2011 | 02:43 PM
terry82's Avatar
terry82
they did my tbi.
Old Jun 26, 2011 | 06:32 PM
Thmprr's Avatar
Thmprr
I once had one of the early Holley Projection 4 units with the 3 screw adjustments on a 460 Ford in a Cobra, could not get it to adjust well enough, actually burnt a piston so we took it off and fitted a 870cfm Holley Street Avenger and it went way better. Now that they have the self learner type units, I'd be sure that it would be fine.
Old Jun 26, 2011 | 08:26 PM
Fast81's Avatar
Fast81
My Pro-jection unit has been flawless on FAST81 since 1997/8.
Getting it set up takes some patience, but it works well when you get there.
BTW - mine is only the 2BRL version
Old Jun 27, 2011 | 09:16 AM
69 Chevy's Avatar
69 Chevy
It needs a tach signal to operate. So, won't work with a magneto. Mine is the original model circa mid 90's.
To Holly pro-jection 4 question
