'76 Tilt & Tele Lever
The retainer is mearly an additional safety measure to make sure that if someone forgot to tighten the steering wheel nut, that nut could not back completely off of the shaft and the steering wheel and hub end up in your lap.
Now to try and tackle your other problem. I really don't understand about the telescope locking lever having "too much play and can't be installed properly."
Even without the steering wheel in place, you should be able to install the star screw and tighten it down with a phillips screwdriver. At that point, the screw should be tight and the upper steering shaft should be locked and not telescope. With the star screw tight, the telescope locking lever should be attached to the star screw with two tiny screws that fit into the scallops on the star screw head.
Now you need to install all the steering wheel, horn, and telescope locking parts for your 1976, but if the star screw is tight the locking lever should be tight as well.
Jim
Now, keeping in mind this retainer and turning to the tele lever, this lever wobbles even with the star screw tight, locking the upper shaft and the 2 tiny screws installed. It seems as though when I initially had the nut retainer installed on the first serration, it provided a base for the lever to sit, keeping it from wobbling.
In your "1969-1982 T & T Steering Column Disassembly and Repair Instruction Paper #1, you make reference to installing a spacer just before installing the tele lever in your "Adjusting the Telescoping Lever" section on the top of page 12. Does the lever sit on this spacer? My '76 has no spacer which seems is needed to provide a seat for the lever to prevent it from moving side to side(wobbling) even though the upper shaft is locked in place with the star screw installed. It seems without something directly underneath the lever, it cannot be secured even with the two small screws installed. So my question is, does the nut retainer take the place of the spacer? In doing so, it would then be dual functional, being both a nut retainer and a lever spacer.
I hope I'm making this clear but it is hard to do so w/o visually showing you the problem. Many thanks for your help, Jim
I still don't understand the lever wobble problem. When you rotate the lever clockwise until it locks the upper steering shaft from telescoping, I just don't see how the star screw (and the lever) can wobble.
When you rotate the lever CCW, there might be a small amount of clearance in the star screw threads so that the lever may seem a little loose. But that is only when you are adjusting the telecope function.
The steering wheel nut retainer goes in the groove right at the end of the steering column shaft. It typically isn't even touching the steering wheel nut. It just prevents the nut from coming off the shaft if it was not tightened properly.
Jim
Jud
