71 Auto Shift problem
Old Jun 26, 2011 | 12:22 AM
artcarguy's Avatar
artcarguy
2nd Gear
Default 71 Auto Shift problem
I have a 71 small block w/ auto in AZ. Do not drive much (67K miles). I took it out today and it would not shift to 3rd without excellerating hard then slammed into gear. Once in 3rd it will not excellerate without excessive gas. It was down 1pint in fluid which I topped off but no change. Help.
Old Jun 26, 2011 | 04:16 AM
7T1vette's Avatar
7T1vette
Check the vacuum modulator on the transmission. The down pipe from the intake manifold could have come loose at the manifold fitting or at the modulator. If vacuum is getting down to it OK, pull the hose off the modulator and check for tranny oil in the hose. The modulator could have failed, also. Classic symptoms of a vacuum modulator problem.
You can get replacements at any auto parts store for around $20. They don't look the same as the original 'can', but they work OK.
Old Jun 26, 2011 | 10:34 AM
artcarguy's Avatar
artcarguy
2nd Gear
Thanks very much. I'll check that. Hope that's all it is. Thanks again.
To 71 Auto Shift problem
