what causes backfire on a Q-jet?
I checked the Distributor, and its tight.
my quadrajet doesn't have an actuated choke, thanks to the DSPO, bit I love in south Texas, so it's never been an issue.
On a whim, I flipped the choke to about 1/2 closed... car runs great, no backfire at all. But if I let off the gas, it dies.
Carb problem now?
Hopefully one will determine where the leak is.
a hose? the only 3 that come off the carb and go anywhere are the Distributor advance,
secondary vacuum, and brakebooster, all those connections/hoses look good.
or are we talking intake manifold gasket failure?
So, the likihood of twisting off a 1/2" grade 8 bolt is pretty limited. The tensile strength is over 700 pounds. I dunno, maybe The Rock or Hulk Hogan (or whomever the contemporary big strong guy might be today) might be able to do it.
Use a 6 point socket and a half inch breaker bar.
As for intake manifold failure; I have never seen one fail. Seen them installed improperly, but not on an engine that had been running for some time. Was the intake manifold removed or replaced recently? If so, try re-torquing (in the right sequence).
The one behind the carb goes to the brake booster.
The third line off the carb goes to the PCV valve.
I pulled them and plugged them, one by one, the only one that seemed to make any difference was the brake booster. When I first started the car with that line plugged, I actually idled (at half choke).... for about a minute, then it dies and it was the same old thing. If I let it sit for a few minutes, it would idle again, then start acting up.
edit: for some reason it idled long enough for me to get out of the car and get up by the carb and manually rev it.
There is a loud sucking sound in the intake (down the carb)
that's all it told me. yay.
Valves? not sure about that
Carb- this is very likely, as I've had an issue with it idling since day one, and the DSPO did mention that the carb needed to be tuned. The idle was lean to begin with (It was hot enough I could smell it)
Major Vac leak- plausible, and I experimented with that theory, but couldn't narrow it down.
the odd thing is that the issue (the original issue of backfiring and killing the engine) occurred during a drive, at around 45mph.
now, it does still backfire a bit, but it's very light, almost sounds like something is knocking in the exhaust.
It's also idle for about a minute (at around 1000rpm) and then die again, but that's only on the first start about every half hour or so.
