Electric headlight motors
Old Jun 28, 2011 | 01:26 PM
AV8RSVT#1's Avatar
AV8RSVT#1
Default Electric headlight motors
I have A 72 and am thinking about converting over to electric headlight motors. At A later date electric wiper door motor. Has anyone done this? Is there A kit to purchase?
Gary
Old Jun 28, 2011 | 01:39 PM
...Roger...'s Avatar
...Roger...
Do a search,there are many many electric headlight threads.
Old Jun 28, 2011 | 01:41 PM
71_S-Ray's Avatar
71_S-Ray
YES, I just found a kit to convert headlights to electric the other day.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
Old Jun 28, 2011 | 02:20 PM
7t9l82's Avatar
7t9l82
still don't see the value in converting the factory system works well is not overly expensive to repair but does from time to time need maintenance. if one side needs a canister replace both or next week you will be doing the other.
Old Jun 28, 2011 | 02:26 PM
Mike Ward's Avatar
Mike Ward
WOW and ONLY a THOUSAND DOLLARS!
I'll fix anybody's car on site for only $500, plus parts and travel/lodging expenses.
Old Jun 28, 2011 | 06:11 PM
mrvette's Avatar
mrvette
www.mcspeed.com IF he still makes them....
some of his parts and then the addition of some Firebird? junkyard motors....
less than 400 bux...
but then, I did mine a tad differently...
look at the sites, it's on there somewhere...
Old Jun 28, 2011 | 06:27 PM
V8Ranger's Avatar
V8Ranger
I converted my headlights to electric with the 'killer lights' kit from mcspeed.com. Kit was $79, Firebird rebuilt motors/C4 headlight controller (ebay) $112, used C4 headlight switch (ebay) $8. Spend another $150 rebuilding the rest of the headlight assembly.
Works great. Of course when I started, EVERYTHING in the vacuum setup was bad/rusted out.
That was late last year, so perhaps mcspeed still sells them.
Carl
Old Jun 28, 2011 | 06:58 PM
68 NJConv 454's Avatar
68 NJConv 454
I did the same mcspeed kit with firebird motors and C4 control module.
Cost me a bit more b/c i wanted new parts.
I'm considering converting to the lemans style fixed headlights over the winter.
If anyone is interested in buying my complete electric setup I might sell over the winter.
I also have the entire headlight harness upgrade with relays that I was planning on selling with the electric motor kit. The harness wasn't cheap but does remove the load of the system off the headlight switch which causes a fair amount of fires in our cars. Harness was cheaper than a new car.
http://www.ecklerscorvette.com/corve...1968-1982.html
You can use an electric actuator motor for the wiper door if you have a 68.
Old Jun 28, 2011 | 11:55 PM
Ray Y's Avatar
Ray Y
I went with the Killer Lights brackets as well and Firebird module/motors. I kept the stock C3 headlight switch. Works great.
Wiper door conversion was done with a linear actuator motor.
Old Jun 29, 2011 | 06:51 AM
7T1vette's Avatar
7T1vette
Or you can fix your vacuum system for 'peanuts' (comparitively, anyway) by purchasing a $10 manual on the operation and diagnosis of the C3 vacuum system, a $20 vacuum gauge, and the time to read/understand the manual. Then just go out and do it.
Now, if the entire vacuum system has already been stripped out of your car, it's a 'toss up' as to which system to replace it with. (Remember....the C2 system was electric....the C3 system went to vacuum...)
Old Jun 29, 2011 | 12:15 PM
bluthundr's Avatar
bluthundr
I used the McSpeed kit, junkyard motors and control module, bought new metal gears off eBay to replace the stock plastic ones, and it works great.
Old Jun 29, 2011 | 12:20 PM
AV8RSVT#1's Avatar
AV8RSVT#1
WOW! thanks for he input. Everything is still there still undecided.
To Electric headlight motors
