overdrive
Old Jun 27, 2011 | 08:24 PM
mcmsmsc's Avatar
mcmsmsc
Default overdrive
wondering if anyone has put an overdrive in there 1970's vette. what options are there, what kind of cost and how much work?
thanks
Old Jun 27, 2011 | 08:42 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Are you asking about an auto 4 speed OD, a 5 or 6 speed manual or the Gear vendors OD unit? Need more info.
Old Jun 27, 2011 | 08:58 PM
Gordonm's Avatar
Gordonm
I put a 5 speed Tremec OD in mine and now have a T56 6 speed with 2 overdrives in it. Ihave installed many 5 speed ODs in difeerent Vettes. Which one would you like info on there are a bunch of options. Also automatic ODs are common.
Old Jun 27, 2011 | 10:31 PM
mcmsmsc's Avatar
mcmsmsc
sorry wondering about the automatic overdrive any style.
Old Jun 27, 2011 | 11:47 PM
eagle275's Avatar
eagle275
Gear Vendors will require alot of mods. Got one on my truck, but did not want to attempt on my Vette. You can do TH-200R4, 700r4, etc. Good luck!
Old Jun 28, 2011 | 11:08 PM
Imo Apita's Avatar
Imo Apita
If you search you'll find a bunch of info on 700R4 swaps. If you search on my username you'll find a couple.
I'm currently considering a 5-speed manual swap. Seems to be a little more friendly on the wallet.
Old Jun 29, 2011 | 06:45 AM
7T1vette's Avatar
7T1vette
If you don't have a lot of HP/torque, a nicely rebuilt 200-4R will swap with a THM-400 pretty easily. No driveshaft change, but I think you still need a saddle-type yoke for the transmission output (different journal diameter for the 400). The periperals (T.V. cable/bracket and tranny pan brackets) are also required and can be found in conversion kits from some of the tranny rebuilders.
Old Jun 29, 2011 | 08:14 AM
sakins.02vert's Avatar
sakins.02vert
it the tremec 5 speed a drop in. That is, if you have a th400 already. Is there a need for an adapter between the bell and trans and will the same driveshaft work?
Found this one:
http://www.ddperformance.com/shop/in...p?cPath=107_89
Trying to decide between this and a 94 Ford T5
Old Jun 29, 2011 | 09:59 AM
mrvette's Avatar
mrvette
The easiest/friendly one to install is the 200 4r, and you should be able to locate a core and rebuild it yourself....
Use a TRANS GO shift kit, no other.....you can find parts off ebay and even converters.....use a ten vane front pump, leave NO section of the tranny together, it must be taken down and cleaned completely....
total cost should be less than 600 bux.....
need a thm350 vette output yoke for the driveshaft you will not need to shorten or modify....the tranny tail shaft should set right on your cross support directly....use your present shifter setup....
To overdrive
