Is this a vent line
Old Jun 29, 2011 | 10:09 AM
Snoopysvet's Avatar
Snoopysvet
Default Is this a vent line
I am replacing the hoses to me vacuum canister, the bottom hose does not seem to go anywhere, is it a vent?
Old Jun 29, 2011 | 10:57 AM
GS977's Avatar
GS977
it's hard to tell from that pic, but mine only has 1 outlet on the bottom. it's a big @1/2 in. rubber hose @ 6 in long that is a vent.
Old Jun 29, 2011 | 11:58 AM
Snoopysvet's Avatar
Snoopysvet
I made the picture bigger
Old Jun 29, 2011 | 12:00 PM
7T1vette's Avatar
7T1vette
The only nipples on the canister are the three on top and they are all connected (line from fuel tank, line from carb manifold vacuum source, line to PCV and/or to carb inlet at base). If you also have a fitting on the bottom of the canister, I think that's a drain for any accumulated liquid.
Old Jun 29, 2011 | 12:08 PM
Snoopysvet's Avatar
Snoopysvet
Awesome, as I could not find anything that looks like it connects there, I think it is a vent or like you said some sort of drain.
Old Jun 29, 2011 | 04:20 PM
Snoopysvet's Avatar
Snoopysvet
No wording at the bottom...
I have this book
Here is a schematic showing only 5 connections, I have 5 on top and the one at the bottom...
Here is a pic of the top of the can showing the 5 hoses...
Old Jun 29, 2011 | 05:40 PM
Snoopysvet's Avatar
Snoopysvet
I found this online?
Old Jun 29, 2011 | 07:38 PM
GS977's Avatar
GS977
ok thats just like mine. you should have a hose on it @4-6 in . it is just a vent or drain hose. the hose goes toward the rear and hooks up to nothing.
Old Jun 30, 2011 | 10:42 AM
Snoopysvet's Avatar
Snoopysvet
Friggin Awesome!
Old Jun 30, 2011 | 01:32 PM
7T1vette's Avatar
7T1vette
If there is a hole below that canister [open to the ground], that drain hose should run through it.
To Is this a vent line
