which gaskets should I replace
Old Apr 24, 2002 | 06:46 PM
szercer's Avatar
szercer
Default which gaskets should I replace
gonna put a camshaft, intake manifold in and not sure what gaskets I should replace while I'm in there... should I just buy the engine overhaul kit for $25 at jegs and put in what I can or spend 80 on the ultra seal set from mr gasket or do I even need to do that yet?
Old Apr 24, 2002 | 09:14 PM
ReydeSol774bbl's Avatar
ReydeSol774bbl
Default Re: which gaskets should I replace (szercer)
I replaced all of the gaskets while I was there excepting the oil pan, which from what I understand the engine has to be pulled to remove the oil pan.
Old Apr 24, 2002 | 09:29 PM
tnt76vette's Avatar
tnt76vette
Default Re: which gaskets should I replace (ReydeSol774bbl)
All you need is a good "Cam Install Gasket Set"....any place where U get your cam oughta have em. Since timing chain has to come off for cam install, it is an excellent idea for the money to install a new double roller (at least) timing chain set.....its cheap insurance.......GOOD LUCK :seeya NOTE TO REY: I'm sure I can change my oil pan gasket without jerking the motor.
[Modified by tnt76vette, 8:32 PM 4/24/2002]
[Modified by tnt76vette, 9:01 PM 4/24/2002]
To which gaskets should I replace
