starts in gear
Old Jun 30, 2011 | 04:57 PM
zigvs's Avatar
zigvs
Default starts in gear
How do you check/adjust the neutral safety swit on a 69 350/auto?
Old Jun 30, 2011 | 06:21 PM
7T1vette's Avatar
7T1vette
Disconnect one of the battery wires; remove the 'release' **** on the shifter; remove the spring; remove the shifter ball; remove the top plate on the tranny console.
The neutral start switch (NSS) is mounted to the right side of the shifter mechanism. It is a switch that should only make continuity when the shift selector is in Neutral and Park. And, it should NOT have continuity in any of the other positions (no matter how much you wiggle the shifter around when in those ranges).
Find the connector for the NSS switch...I think it is two purple wires. Disconnect it from the harness. Connect an ohmmeter to the two connector terminals. Put key in ignition and turn to ON position (battery is still disconnected). Shift through all the gear ranges, neutral and park; wiggle the shifter around in every range. The NSS should always make connection anywhere in Park & Neutral...and it should never make connection in the other ranges. You can adjust it by loosening the screws at the ends of the switch and repositioning the switch on the shifter tower.
Note: DO NOT attempt to make this adjustment with the battery power connected. If the NSS isn't set right, and you try to start the car when 'in range', you may just power your way through the garage door!
Old Jun 30, 2011 | 11:53 PM
zigvs's Avatar
zigvs
thanks
Old Jul 1, 2011 | 11:10 AM
boltnut's Avatar
boltnut
is this the same procedure for a 73 ?
Old Jul 3, 2011 | 11:44 AM
7T1vette's Avatar
7T1vette
They should all be very similar (if not identical). Check your wiring diagram for wiring colors. Same process should be used to check them out.
Old Jul 3, 2011 | 01:49 PM
...Roger...'s Avatar
...Roger...
12 purple is common to all.
Some have variations depending on year,these should be very close.
....68-purple-purple
69-73-purple-purple/white tracer
74-75-purple-green/white tracer-this is the cars with seat belt interlock
76-77-purple-purple/white tracer
78-82-purple-yellow
To starts in gear
