Blower motor
Old Jun 30, 2011 | 10:55 PM
Richard68's Avatar
Richard68
6th Gear
Default Blower motor
68 327 CHANGED THE BLOWER SWITCH STILL DOESNT WORK, ANY SUGGESTIONS ???
Thanks, Rich
Old Jun 30, 2011 | 11:33 PM
7T1vette's Avatar
7T1vette
Well, it would help if we knew what your "symptoms" were. (All we know now is that you changed the switch and it doesn't work...)
Old Jul 1, 2011 | 06:29 AM
rbowman's Avatar
rbowman
Check the ground wire. I started the blower motor and tested it by running a wire from the blower motor to a good ground. Most of the issues I've come acorss has been fixed by regrounding.
Ron
Old Jul 1, 2011 | 07:51 AM
sweeet76's Avatar
sweeet76
Although 7T1vette is right, ground wire could be a sure bet.
Old Jul 1, 2011 | 11:31 PM
Richard68's Avatar
Richard68
6th Gear
that is the sympton it doesnt turn the blower on !!!
Then too my lights stay up and wiper door stays open.
Rich
Old Jul 3, 2011 | 11:41 AM
7T1vette's Avatar
7T1vette
Check the pull-down switches (manual override) under the steering column. If they are pulled down, the wiper door and headlights will stay "up".
Old Jul 3, 2011 | 01:25 PM
Bob Onit's Avatar
Bob Onit
Not sure about the '68 but my '73 has the relay on the passenger side blower housing.
Pull the plug and test the leads for voltage with the blower switch on low or medium speed.
The reason I say low or medium is because the high speed setting has an inline fuse tucked under the drivers side inner fender (again, this is how it is setup on the '73 model, not sure about the '68) and if the fuse is blown you'll get nothing on your meter.
Oh yeah, to confuse things a little more my '73 has A/C
Old Jul 3, 2011 | 04:07 PM
Big Block 69's Avatar
Big Block 69
Check to see if the ground is hooked to a bellhousing bolt on the passenger side near the starter.
To Blower motor
