Brake Caliper Question
Old Jul 2, 2011 | 02:16 PM
73Tahitian's Avatar
73Tahitian
Default Brake Caliper Question
I have an original 73BB and my rear caliper has a leak. I would like to rebuild these myself and want to convert them to the oring using a kit. Since these are the original calipers they are not SS sleeved. Can I still use the oring kit even if the calipers are not SS sleeved?
Old Jul 2, 2011 | 02:59 PM
Scott Marzahl's Avatar
Scott Marzahl
You can use an O ring kit with the steel bores, IF the bores aren't all pitted out, which is more times than none with these old cars.
Old Jul 2, 2011 | 03:54 PM
7t9l82's Avatar
7t9l82
hard to imagine they haven't been sleeved after all these years
Old Jul 3, 2011 | 12:08 PM
73Tahitian's Avatar
73Tahitian
Actually the steel bores look good, however there are pits at the bottom of the calipers. I will give it a shot and if it leaks I will just purchase a set with SS sleeved.
These are the originals. The car has been stored most of its life. It only has 36K original miles.
Thanks for the replies.
Old Jul 3, 2011 | 12:12 PM
Mike Ward's Avatar
Mike Ward
Some of the brake caliper vendor will SS sleeve your own calipers and send them back to you. Might be an opportune time to do it.
Old Jul 3, 2011 | 12:23 PM
73Tahitian's Avatar
73Tahitian
Thanks Mike. I will look into that.
Old Jul 5, 2011 | 09:02 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
We would be happy to have your sleeved and rebuilt with the O-ring pistons and seals. Let me know if we can help
Andrew
800-442-0335
To Brake Caliper Question
