No electrical power help
Old Jul 2, 2011 | 10:20 PM
alyle5864's Avatar
alyle5864
Banned Scam/Spammer
Default No electrical power help
Had the '76 out of the garage while I cleaned up abit. Pulled it back into the garage and shut it off while I went to grab my tools to do some timing checks and tried to start the car, no power. I have no power to anything, not the clock, lights anything. Checked the battery connected and with the ground off, 12 volts. Nothing powers up in ACC or On via the ignition switch.
Where do I start to troubleshoot this????????
Old Jul 2, 2011 | 10:57 PM
terry82's Avatar
terry82
on my 82 there is a connector[6 wires] that is behind the passenger motor head that goes down to the starter .if your car has that check there.if not go on down and check the starter for power.
Old Jul 2, 2011 | 11:45 PM
Vette5.5's Avatar
Vette5.5
Start with the battery, as had this happen more than once. Everythings fine one minute, then click, the battery just internally shorted out. Checking a battery with a meter open circuit mean's very little, as really needing a load on it. Most auto parts places can do this. Could be a fusible link inline, but not sure where on a 76'.
Old Jul 3, 2011 | 09:42 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The 76 has a fusible link right by the left hand inner fender. Look at the firewall for a large red wire and then follow it. The link is inline with that red wire. If the link blows, it takes out all the power inside the car.
Old Jul 4, 2011 | 09:10 PM
alyle5864's Avatar
alyle5864
Banned Scam/Spammer
Problem corrected I hope, changed batteries now have power. Thanks for your suggestions.
Old Jul 4, 2011 | 09:25 PM
terry82's Avatar
terry82
good call on the battery i ASSUMED it had been checked and was good.
Old Jul 4, 2011 | 11:51 PM
alyle5864's Avatar
alyle5864
Banned Scam/Spammer
Well I was about to pull the fuseable link in the left fender well (checked and had 12v on one side) and replace it when I decided to hook the battery up again. When I did, the lights came back on. Tried to start the motor and got a click and the lights went out again. So I pulled the battery and put another one in and power came back. Started the car, ran until warm and shut it off. Waited a couple minutes and restarted and shut down a couple times, no problems. Apparently my battery went bad. After pulling it, I checked it with a meter and it read 130v!!!!?????
To No electrical power help
