timing
Old Jul 5, 2011 | 11:37 AM
manfroni's Avatar
manfroni
Default timing
Need some help, I have read all of the Lars threads on timing and I think I am missing something. '78 383 initial is set at 15 degrees. All I can get for advance is 28 degrees at about 2,000 rpm with the vacuum advance disconnected. I revved the engine to 3,500 rpm and the light stayed right at 28 degrees. I did install the lightest springs form a Morosco kit. Any idea what I am missing? There is a number stamped on the weights, it is 42. Help
Old Jul 5, 2011 | 11:45 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
some times there are mechanical things that impact the advance.....holes need to be elongated some times and some times holes need to be welded closed.....look at the mechanism that is stopping the mechanical advance from moving.....also may not be a bad idea to make sure TDC is marked properly on balancer and timimng tab.
what kind of distributor is this? points or HEI
Old Jul 5, 2011 | 12:51 PM
jackson's Avatar
jackson
maybe the springs are too light ... fully-extended at low rpm ?
-add-
if ya do some drilling here ... you'll pass thru a sewer with alotta tripe about cam oil ... even a naked emperor or two ... but there's some gold a bit deeper ... including BarryK's timing thread; many think it's a nice adjunct to the good work of Lars.
http://forums.corvetteforum.com/c3-t...long-post.html
Old Jul 5, 2011 | 12:54 PM
MelWff's Avatar
MelWff
try reinstalling the stock weights and see how much you get, the Moroso weight may be limiting the advance too much.
Old Jul 5, 2011 | 01:43 PM
bobs77vet's Avatar
bobs77vet
are you thinking the shape of the weights are wrong?
Old Jul 5, 2011 | 03:51 PM
Scott Marzahl's Avatar
Scott Marzahl
Its either shape of the weights that is limiting movement or something is in the way to keep them from moving any further. Some of those aftermarket weights are longer and cut different than stock.
Old Jul 5, 2011 | 08:29 PM
'75's Avatar
'75
These are Mr Gasket weights that I had to reshape to get enough advance. Once the weights reacted properly, I had more than enough advance, so I brazed the slots to limit it to what I wanted.
Old Jul 5, 2011 | 08:45 PM
'75's Avatar
'75
I reshimmed the distributor to .015". I also brazed up the slot in the top plate to limit the advance to 20 deg. While I was brazing, I brazed up the retard end of the slot also, my reason is because the springs are so soft that when I would accelerate, it would retard just for a second because the springs were holding the pins away from that end too. Now when the springs and weights are in place, as the weights are at rest the springs are holding it against the retarded end of the slot. I ended up using the aftermarket weights but modified them. The final is 16* initial at 750 rpm, 16* @800. 19* @900, 22* @ 1900, and goes up evenly till 36* all in at 2800.
Old Jul 6, 2011 | 10:13 AM
manfroni's Avatar
manfroni
I am using the original weights, the vacuum canister is stamped 626 and 10. The distributer is factory hei model number 1103337. Any idea of what the spec for advance are for this model distributer?
Old Jul 6, 2011 | 04:21 PM
scottyp99's Avatar
scottyp99
OK, your mechanical advance should be somewhere around 20*. Put the stock springs back in and see where idle timing is at. Don't be too shocked if it is around 8*.
If putting the stock springs back in doesn't reveal that the timing was advanced at idle, then something is keeping it from advancing. take the cap and rotor off and inspect the unit for burrs, casting flash, etc. that might be keeping the advance weights from moving thru their full range of motion.
You said you had read all of Lars's threads on timing, have you ever read any of his papers on timing? He advocates running the ignition with no springs, and setting timing at 36* as the first step in the process. Then put heavy springs in and observe where timing is at at idle. This way, when you put the lighter springs in, you can tell if the springs are advancing the timing at idle, and you aren't playing with the timing anymore, just the curve, because full advance is at 36 and will stay at 36. You are just playing with weights and springs to get the 36* where you want it, without any advance at idle. If you skip steps, you get poor results. Good luck,
Scott
Scott
Old Jul 6, 2011 | 04:28 PM
manfroni's Avatar
manfroni
Thanks Scott. I guess I didn't read everything. But that does make total logical sense.
Old Jul 6, 2011 | 04:43 PM
scottyp99's Avatar
scottyp99
Don't feel bad about missing a little piece of info, Lars packs it in pretty good! The whole timing curve thing is pretty simple.........once you are on the other side of learning it! It can be really confusing until then. And there is still a chance that your problem could be some unrelated freak occurance.
Scott
To timing
