Fog in Window
Old Jul 6, 2011 | 01:17 PM
LaSHOOOOSH's Avatar
LaSHOOOOSH
Default Fog in Window
Hey All,
I did a search and can't seem to find what i am looking for.. I am experiencing fogging in my front window after taking the car out for a drive. When i park it and come back i've got a foggy front window that takes place.. I'm sure theres a fix.. Can someone help me out please? Thanks kindly.
Old Jul 6, 2011 | 01:37 PM
mysixtynine's Avatar
mysixtynine
Sounds like a leaky heater core.
Old Jul 6, 2011 | 01:38 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
What he said...
Old Jul 6, 2011 | 01:39 PM
Roughrider's Avatar
Roughrider
What they both said!
Old Jul 6, 2011 | 01:40 PM
jcloving's Avatar
jcloving
I agree. Another thought was that somehow your ac might be blowing thru the defroster and causing condensation there. Maybe that's a long shot.
Old Jul 6, 2011 | 01:41 PM
MelWff's Avatar
MelWff
do you smell antifreeze? does your car have air conditioning and are you using it while driving?
Old Jul 6, 2011 | 02:29 PM
LaSHOOOOSH's Avatar
LaSHOOOOSH
I do not smell any antifreeze.. But i do have AC in the car.. I'll have to check next time i'm out an about to see if the AC is running..
Is a heater core leak easy to fix if that's my issue?
Old Jul 6, 2011 | 02:41 PM
mysixtynine
You have to first figure out what it is. Moisture on your windshield would indicate moisture in the ac/heater box. Is the moisture inside the car or outside.
You may just have gunk clogging up the drain for the evaporator and its staying wet inside instead of draining out.
You would know if its antifreeze. The smell is pretty unmistakable. But we don't know what you have as far as coolant is concerned.
Is it a big job... with AC, we'll say there's more to take out to get to the heater core.
Old Jul 6, 2011 | 04:01 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
yeah the guys have this one right....foggy windows almost always mean leaking heater core
Old Jul 6, 2011 | 04:32 PM
LaSHOOOOSH's Avatar
LaSHOOOOSH
The fogging is only taking place on the interior of the front windshield more on the right side then the left.
Old Jul 6, 2011 | 04:48 PM
Jud Chapin's Avatar
Jud Chapin
It's strange you don't smell the coolant (antifreeze), if in fact you have a fair mix of it with your water in the cooling system. Sometimes it will actually leak into the cabin on the pax side. There should be a film on the windshield, inside, which would be residue from the coolant. You can see this easily by just slightly wiping the windshield with your finger.
Old Jul 6, 2011 | 07:09 PM
C3 4ME's Avatar
C3 4ME
my thought is that you just have something damp, or wet inside. especially this time of year, I can see where condensation might accumulate on the inside of the window. It might not be a heater core leak, but I bet you've got a leak of some sort somewhere.
Old Jul 6, 2011 | 08:02 PM
Duane4238's Avatar
Duane4238
Just another idea, if you don't have a heater core leak. If you are driving with the A/C on, it will cool the windshield where the defroster hits it. Then when you park and turn the car off and open the door to get out, you are letting warm, moist air into the car. The new moisture might then be condensing on the inside of the cold glass. Just a thought!
Duane
To Fog in Window
