Coil voltage
Old Jul 7, 2011 | 03:21 PM
AvRog's Avatar
AvRog
Default Coil voltage
How much voltage should I read at the positive side of the coil with my ignition key "on". 69 427 points.
Old Jul 7, 2011 | 04:04 PM
Mashman's Avatar
Mashman
Assuming you have points, with the car not running, you should see either something around 6 or 12 volts depending on whether or not the points are open. If the car is running you will get the average of these, and therefore should see between 9-10 volts.
Old Jul 7, 2011 | 04:53 PM
...Roger...'s Avatar
...Roger...
Don't be surprised if you see 12 volts. The resistor wire is there to limit amperage , not voltage.
EDIT:
Found this thread,this should answer your more in depth questions.
http://forums.corvetteforum.com/c3-t...vaoltag-s.html
Old Jul 7, 2011 | 05:31 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Well done, Grasshopper.
Old Jul 7, 2011 | 06:32 PM
Mashman's Avatar
Mashman
EDIT:
Thanks! I guess I learned my lesson well!
Old Jul 7, 2011 | 07:04 PM
...Roger...
Same here , Mike (69427) is a good ( and patient ) teacher.
Old Jul 7, 2011 | 08:13 PM
AvRog's Avatar
AvRog
EDIT:
Thanks All, that answers my question.
Later, Rog.
To Coil voltage
