Pegged the temp gauge, damage ?
Hey, man, I'm just pulling your leg!! Your engine's fine........probably. D'oh, there I go again, with the leg-pulling!
Scott
As stated above, to be sure a pressure test should be done.
Get rid of those fan controllers and make one yourself. When I saw that there was smoke coming from under my hood, and a small FIRE consuming my fan controller, I knew it was time to build on the right way.
Mine is very simple and consists of:
2 Hella 40A headlight relays
2 weather-tight 10 gauge in line fuse holders
1 195* temperature switch
and some 10 gauge wire to go from the alternator to the relays, then from the relays to the fans, and then from the fans to the frame (ground)
Racing, cruising, and beach traffic... Never had one issue.
If you want, I can look up my part numbers and make a quick wiring diagram.
Scott
You just lost the game!!!
