Trailing arm bushings
Old Apr 25, 2002 | 11:27 AM
Milest's Avatar
Milest
Default Trailing arm bushings
I am seeking information on what is involved to replace my trailing arm bushings. The wheel bearings are fine as is the emergency brake.
I have heard it is a nightmare, but would like a little more information on the steps and tools required. Can it be done in a home shop for example?
Thank you all
Old Apr 26, 2002 | 12:36 AM
Milest's Avatar
Milest
Default Re: Trailing arm bushings (Milest)
To the top
Old Apr 26, 2002 | 01:48 AM
LATNC3's Avatar
LATNC3
cool car...what was your question??? trailing arm bushings? what do you need to know.
Rod
Old Apr 26, 2002 | 11:19 AM
GTR1999's Avatar
GTR1999
TO replace with the stock rubber bushings you have to remove the T arm from the frame. The problem with doing this can be the cross bolt. If it's rusty then you may have to either torch it or sawzall it out. I just did 2 of these a couple of weeks ago and sawedone and torched the other. Both a PITA to do.
Once you get the arm out the bushing has to be cut or drilled out You will need a flaring tool to get the new bushing sleeve installed correctly. You can buy or make one.
I never have installed thepoly bushings but hear they are much easier to install. I don't know how they compare to the rubber for either ride or performance.
gary
Old Apr 26, 2002 | 03:04 PM
Frank75's Avatar
Frank75
Default Re: Trailing arm bushings (gtr1999)
More info here: http://www.bokonon.net/corvettefaq/susp.asp
[Modified by Frank75, 1:05 PM 4/26/2002]
Old Apr 26, 2002 | 08:26 PM
Juliet's Avatar
Juliet
It's a lot of basic wrenching to get the T-arms off. I also took out the entire rear suspension and drivetrain from the drive shaft back. I was lucky with the T-arm bolts on mine. They came out real easy the first 1/2 of the way. The second half I had to use some shim pieces Greg cut for me out of some scrap angle metal pieces which I was able to pry against with the monster screwdriver to get the bolt out the remainder of the way. Fortunately the came out in one piece & I had the bolts replated. I took the T-arms to Tony's corvette for a rebuild. I haven't done the reassembly yet though. ~Juliet
To Trailing arm bushings
