T56
Old Jul 8, 2011 | 09:16 AM
sakins.02vert's Avatar
sakins.02vert
Default T56
Will a T56 form a C5 fit in a 76 L-82? I have a removable crossmember.
Do I have to:
1. move the shifter forward
2. cut the driveshaft down a few inches.
3. modify your cross member to let the tranny sit lower.
Anything else?
I see one online and I'm wondering if this requires less custom work than the Ford t5 ?
Old Jul 8, 2011 | 09:57 AM
Corey_68's Avatar
Corey_68
Do I have to:
Anything else
A C5 T56 will not work as they are rear mounted to the rear end and connected to the engine via a torque tube. You need a F-body Lt1 T56 tranny as the LS1 based trans will not bolt up to a Gen 1 engine.
Old Jul 8, 2011 | 11:35 AM
Gordonm's Avatar
Gordonm
I have an LS based T56 in mine. It came from a 06 GTO. It is the same trans used in the Vettes but it is for the GTO and the the rear mounted Vette trans. The C5 and C6 T56 from Vettes will not work at all. The LS based T56 will fit but needs a spacer of about .400 but you can also buy a bellhousing from Quick time that is spaced correctly. It requires a ton of work to get it into the C3 body and if yo uare not skilled in this or have fab ability it is a rough install. I have a lift and capability to do this and it still took a while. There is no output for a cable driven speedo, reverse lockout wiring and lots more.
Old Jul 8, 2011 | 02:19 PM
Corey_68's Avatar
Corey_68
Gordon, what about the input shaft on the LS t56, I was told itt was different than the LT1 based trans and would not work on gen 1 engine? Any truth to this?
Old Jul 8, 2011 | 02:40 PM
Gordonm's Avatar
Gordonm
I am using the same roller bearing i have used for the Muncie and the Tremec and the T56. the only thing is it needed a spacer to move it out a little. Like I said above I think the spacer is .400 thick. Other than that it is working. I am using the LS hydraulic style throwout bearing also
Old Jul 8, 2011 | 05:11 PM
sakins.02vert
Thanks guys.
So if I went with the t56 from a lt1, that would bolt right up to a standard chevy bellhousing (621) and my sm350?
Is a t5 out of a Ford less work to make it fit/work? I know with the ford I need an adapter between the trans and bellhousing. If it's 92 or older I can buy that adapter from wilcap.com. If newer, I'm not sure where I can get the adapter from.
Old Jul 8, 2011 | 10:50 PM
85camarocrazee's Avatar
85camarocrazee
You have a ton of research to do. An lt1 t56 will bolt to an earlier style 350. However, make sure you get the right flywheel from centerforce if the motor is a 2pc style rear main seal. If its a 1 pc style motor that you have, go ahead and use the flywheel and everything. bolt and go. Obviously you will have to make some changes at the rear of the trans such as crossmember and driveshaft adjustments but its pretty straightforward. Not a swap for the faint of heart and time consuming making sure everything is perfect. google c3 t56 and start reading!!!! read til your head hurts and the wife is lonely, then read some more!
Old Jul 9, 2011 | 08:22 AM
sakins.02vert
Oh trust me. i'm driving everyone I know crazy with researching all kinds of 4, 5 and 6 speed transmissions...:-)
This is good to know, thanks. At this point I have an automatic 76 sb350 so I need everything. Just looking for the right transmission based on what's available.
Old Jul 9, 2011 | 10:56 AM
85camarocrazee
I would use a 94 to 97 lt1 t56 as the earlier 93 t56 had some goofy gearing in it. Get a centerforce flwheel and bolt that sucker in. A stock clutch on an lt1 can hold 400 hp but not much more. buy a clutch master cyl from a 1985 1 ton and you will have to modify it by cutting the shaft and threading it so its adjustable. reuse all of the other lt1 t56 stock clutch hydros. find pedals out of manual trans c3 that someone is selling move trans crossmember back (trial fit before mounting basically EASY) and have someone shorten your stock driveshaft. also goin to either modify the trans tunnel or buy a shifter that is et to come up in the stock location instead of centered in the center console which leads to converting your console from auto to manual - lots mre reading but I think from here you should have no problems. Personally i would want to stay away from the ford trans as its 1 more step. Or call up Kiesler trannys and tell em what youre doing. They will send you a complete crate full of what you need.
Old Jul 9, 2011 | 01:23 PM
tt 383's Avatar
tt 383
With something that powerful, a 5 spd would suffice. MMR has TKO 5spds rated at 750 and 900 hp. These are for Fords, but no reason they couldn't build on a Chevy version.
Old Jul 10, 2011 | 10:58 AM
85camarocrazee
Yeah but its a 5spd lol. I went with a 6 because with 3.73's im running 1850rpm at 70 miles an hour.
Old Jul 10, 2011 | 11:13 AM
MIKE80's Avatar
MIKE80
I'm still working on my T56 install. Newborn baby has everything on hold right now
http://forums.corvetteforum.com/c3-t...aigs-list.html
Old Jul 20, 2011 | 01:29 PM
sakins.02vert
I know you guys said a t-56 out of a C5 will not work. I just found a t-56 out of a 1996 corvette. Is that going to work?
Old Jul 20, 2011 | 01:33 PM
sakins.02vert
Please pardon my ignorance but does the 96 corvette t-56 fit into the category of the '93 to '97 f-body? Therefore this could be a good fit for my c3?
Old Jul 20, 2011 | 01:52 PM
sakins.02vert
Sorry, dumb question. F-Body is Firebird/camaro. Corvette is not in that category and therefore this 1996 corvette t-56 is not going to work well in a C3.
Old Jul 20, 2011 | 09:40 PM
Bugman Jeff's Avatar
Bugman Jeff
IIRC, the LT1/LT4 Corvettes used a ZF 6 speed, not the T56 that the F-bodys used. The ZF is physically larger, making it more work to fit. Internal parts are more expensive as well if they ever need to be replaced.
To T56
