New Autometer Gauges
Old Jul 8, 2011 | 06:56 PM
dduenkel's Avatar
dduenkel
Default New Autometer Gauges (PICS)
I decided to put Autometer American Muscle gauges in my 71 convertible. This forum was great in learning how to fit the speedometer and tach with the mounting gasket made of Lexan. Also what to do with the turn signals, break light and high beam indicator... Thanks for all the posts and a great search function, made it really easy.
Just need to wire things up now but wanted to show a couple pictures...
Dan
Old Jul 8, 2011 | 07:50 PM
77-Shark's Avatar
77-Shark
I like it. Did they come with new boards? How was the fit/finish?
Old Jul 8, 2011 | 08:44 PM
dduenkel's Avatar
dduenkel
I had to make the some boards to mount the gauges on, it is clear Lexan that I cut and then painted black in flat paint. The fit is real nice and it only took about 15 minutes for each gauge. There are some articles on the forum that say how to make them. Pretty easy.
Old Jul 8, 2011 | 08:46 PM
eagle275's Avatar
eagle275
do you have a link that shows how to do all of that? Thanx! BTW, those new gauges are really nice!
Old Jul 8, 2011 | 09:04 PM
tortisevette's Avatar
tortisevette
You did the right thing getting full sweep gauges. They're higher quality and will be more accurate and more percise although more expensive. I picked up some short sweep ultra lites cheap and am not that happy. My gas gauage i bought separately is full sweep and i really like it. The voltmeter pointer is stuck against the case. Temp gauge reads high and reflects head temp rather than water temp. Oil pressure is hard to read because of the large scale going all the way to 100 psi. Put these in a week ago.
Old Jul 8, 2011 | 09:29 PM
TPI BOY's Avatar
TPI BOY
Looks good
Old Jul 8, 2011 | 09:37 PM
vette427-sbc's Avatar
vette427-sbc
Nice work!
That gauge style is very cool too
Old Jul 8, 2011 | 09:43 PM
TPI BOY's Avatar
TPI BOY
Are they hard to wire up
Old Jul 8, 2011 | 10:00 PM
Rebelrob's Avatar
Rebelrob
Looks good. I like these after market gauge threads. So were you able to use the old wiring or do you have to use all new wires? Also do these gauges all come with sending units I assume? And your using them.
Wonder how the gas gauge would work with the old rheostat in the tank.?
I worried about the whole pulling the dash apart. Afraid I will not get it back together....
Old Jul 8, 2011 | 10:18 PM
dduenkel's Avatar
dduenkel
I was able to use all the original wiring, the gas gauge is programmable so it will work with existing sending unit...all other gauges came with its own sending unit... I will take some pics tomorrow of the wiring before I put the dash back together. The speedometer is electric so I have to put the converter on the transmission tomorrow I will post how that works and I put in an HEI distributor so the electric tech will be ready to hook up.
Old Jul 8, 2011 | 10:21 PM
myoriginal77's Avatar
myoriginal77
How about that sticker on the back that says removal will cause damage to the electronics ???
Frank
Old Jul 9, 2011 | 10:12 AM
70_Shark's Avatar
70_Shark
Interesting how you handled the turn signal indicators. Much cleaner (and less work) than mine. I also got rid of that stupid radio which never sounded as good as the engine.
Old Jul 10, 2011 | 09:43 AM
silver79's Avatar
silver79
Very Nice work . It will be this NeXT winter's projet for me. Can you post The links for The instructions?
Old Jul 10, 2011 | 08:20 PM
dduenkel's Avatar
dduenkel
Here is the final product...
Here are some of the links I used to figure things out..
http://forums.corvetteforum.com/c3-t...them-here.html
http://forums.corvetteforum.com/c3-t...ease-help.html
http://forums.corvetteforum.com/c3-t...-their-c3.html
There are definitely more posts, just search on Autometer gauges and you can spend all day looking at them.
Overall very happy with the look, but it was a lot of work to re-wire everything! Just glad its over with!
Old Jul 10, 2011 | 08:37 PM
wrc3's Avatar
wrc3
7th Gear
Looks good brother!
Old Jul 10, 2011 | 09:33 PM
GS977's Avatar
GS977
wow, that looks factory. only better!!!!!
Old Jul 10, 2011 | 09:45 PM
77-Shark's Avatar
77-Shark
really nice work. Looks like it could've come from the factory that way!
To New Autometer Gauges
Old Jul 10, 2011 | 11:50 PM
kaiserbud's Avatar
kaiserbud
Wow - these are the nicest aftermarkets I have seen in a C3.... I especially like the full sweep and the center gauges.
I was wondering what those Green/red lights were in the speedo and tach..... I was thinking ohhhh- that may a be a good spot to mount my Gear Vendors indicator lights - rather than in the DIN radio bezel.
They look fantastic with that blue color on the body !!!!!!
Old Jul 11, 2011 | 12:01 AM
eagle275's Avatar
eagle275
Hows the GV project coming along? I just had the fluid changed in my GV 4X4. Synthetic of course.
Old Jul 11, 2011 | 12:37 AM
kaiserbud's Avatar
kaiserbud
ehhhh. .....will respond on my thread. thanks for asking.
