Hi, I have a model 4160, LIST# 6619-1 Holley squarebore, single feed carb, it's one of those that have the idle screws that work backwards. (in makes it richer) Anyway, I would like to know if I installed this metering block:
I would have to look that up but it may be possible. What would be the advantage other than the direction of the screws? I believe this was a change for the newer engines and can remember some of the metering circuit but not enough.
Not alot of info on the internet about it, but from what I have been able to find, it's not just the direction of the screws that differentiates it from a standard Holley carb. It's a smog/emissions carb, and is supposed to run well on a stock or mild 350, but is difficult to tune on an engine with a big cam. The engine I am thinking about installing it on has a stock cam, but who knows what the future holds? Just looking at options right now, if I can spend $45.00 on a new metering block, and essentially have an 1850 carb, as opposed to spending $300.00 or so, that's a no-brainer. My theory is that the only difference between this carb and an 1850 is the metering block, and I would like some experts to say yes or no on it before I plunk down any money.
I went and looked into this and as far as I can see now it wont work as the idle discharge slot and the curb idle discharge are fed off same feed on your carb. The other carbs are idle transfer slot fed above idle screw and the idle discharge is fed below idle screw allowing more gas air mixture in rather than just closing the extra air circuit off as in your setup.So the carbs would have to have different passages.I still see no reason other than the idle circuit may have to be more accurately set, that this carb wouldnt work on your setup. Its only going to effect your idle and just off idle on the carb. The rest off the carb will function the same. It cant hurt to try it, making sure all gaskets and settings are proper for this carb.
Well, you sure do sound like you know what you are talking about. Alright then, scratch that plan; thanks, you just saved me about 50 bucks and some frustration. Aside from the weird idle setup, it's a normal Holley carb, eh? I guess I can live with it the way it is.
Can you tell me a little about why the idle setup is so different from a normal Holley carb? It is supposed to be an "emissions" carb, maybe it allows for a more precise air/fuel mixture at idle, for emission reasons?
I finished installing it yesterday, and it runs pretty good, even without any tuning so far. Thanks again for the help, dude,
The reason they went to this type setup is that the original idle was tapped into the the idle transfer line. This means it was taking the air and fuel already mixed and adding more in. Therefore making it like a bigger line of fuel air mixture. Never changing the air fuel ratio. Thus these carbs almost never pass emissions. So to counter act this problem Holley placed a complete new line of idle transfer line and idle circuit seperately. They ran a straight fuel mixture line for the idle circuit and the screw was tapped into an air bleed to allow addition of air to the fuel mixture. So by turning outward you actually lean mixture out, and turning it in makes it rich. This is what makes this a good street performance carb. The problem is when people here emmissions they think power loss. I suggest you get that holley carb book, an engine tuning book and learn to tune that thing perfect and not only will you be helping save a dieing art. You will be more in tune with your car and going to love it that much more. Sorry about the long post.
Hmmmm, ya know, That is exactly what I did, I heard "emissions" and figured it was junk. But, if I am understanding you correctly, it's just a regular ol' Holley carb, with a different method of metering the fuel at idle and transition. Instead of metering the already emulsified fuel heading for the idle port, it meters the amount of air going into the emulsification. And that emulsification goes to the idle discharge hole and the idle transition slot, am I understanding correctly?
OK, I am beginning to not look at this carb as an inferior carb, but rather, a "special" carb. Thanks for taking the time to explain all this to me, I appreciate it.
Thats right you have the understanding of what its doing good luck and enjoy. One of the things I like about the holley is that once you understand how it works they are fairly easy to dial in.Not that they are any better than any other carb but they are modular which simplifies some of the work.
