Changing differential ratio
Old Jul 13, 2011 | 12:02 AM
Bob Onit's Avatar
Bob Onit
Default Changing differential ratio
Hi all
I have a '73 coupe with a 3:08 rear in which I installed a ZZ4 a few years ago. I have the original numbers matching L-48 buttoned up under my work bench. The Muncie M20 transmission and the 3:08 differential are original as well.
I would like to change the gearing to 3:36 or 3:55 as the 3:08 is quite depressing to drive with the ZZ4.
My question is can I still use my housing and have lower gears installed or do different ratio differentials require different housings?
If I can use my current housing would anybody have a guess on a ball park figure of what the cost of upgrading might be and where could I get the work done by someone with a good reputation?
In the event I can not use my original housing would anybody have an idea what a good used 3:36 or 3:55 used unit would go for?
Also, any recommendations on the 3:36 vs 3:55 would be extremely helpful since I cant just go and test drive something with the same drive train that I have in mind.
I rarely drive more than 30 minutes on the interstate and I'm not concerned about fuel mileage. Most of my driving is around town and on secondary roads.
Thanks for any info or suggestions.
Bob.
Old Jul 13, 2011 | 01:39 AM
Little Mouse's Avatar
Little Mouse
1966 up M-20 ratios 2.52,1.88.1.46,100. X rear ratio's
7.76,5.79,4.49,3.08
8.46,6.31,4.90,3.36
8.94,6.67,5.18,3.55
9.32,6.95,5.40,3.70
10.35,7.72.6.00,4.11
Having owned 3.08, 3.36, 3.70 ,4.11 with M/20, M-21. Borg warner's ST10s with 2.43 close ratio X 3.70. 2.64 wide ratio X 3.73. Tire dia. ranging from 26" to 29"
Hydraulic roller 350 along with wanting mostly intown accel. with limited freeway driving. Would recomend the 3.70 with 27" tire dia down to 26" dia. If you have less then 26" dia. the 3.55.
3.36 would be so little help to you it would not be worth the cost of a gear change you would be real dissapointed in the difference.
Old Jul 13, 2011 | 05:14 AM
Vette5.5's Avatar
Vette5.5
I'd change the transmission instead. You didn't mention the transmission you have, but if current 1st gear ratio is 2.50, moving to a 700R4 or TKO 5 speed will be similar 1st gear to running a 3.73 axle. Not to mention the 2.20 equivalent highway cruising ratio. Ideally, even with the tranny change, would probably desire a 3.42 axle, but after coughing up for the O.D., rear end work isn't cheap either.
Old Jul 13, 2011 | 06:06 AM
Gordonm's Avatar
Gordonm
Yes you can still use your housing. The 3.08 and the 3.55 use the same interanl components except the ring and pinion is different. You have one of the best rebuiulders in your backyard, Gary Ramadi is in the New haven area. He has rebuilt lots of C3 rears for forum members. The 3.55 is an excellent overall ratio even if yo udo change to a 5 speed trans. I actually have a spare 3.55 in my garage that will probably go into a 5 speed swap in the future for someone. I pick these up when I can get them. The cost is going to depend on what is needed, obviously new ring and pinion. The 3 series carriers will support a 2.73-3.90 gears and there are special thick flange 4.11 gears also available for the 3 series carrier.
Old Jul 13, 2011 | 07:27 AM
JohnRR's Avatar
JohnRR
The 3.55 ratio with your M20 wide ratio gear box would be a nice, conservative combination. Going from 3.55 to the 3.73 ratio will add another 5% to your RPM, Torque, and Fun! Don't waste your time on the 3.36, you'll hardly notice the difference. If you are considering the 4.10 ratio, personally, I enjoyed the 3.73 more than the 4.10's. With the 4.10 gears, you barely get going, and you have to shift right away. Of course, you'll get going much quicker too!
John
Old Jul 13, 2011 | 08:56 AM
...Roger...'s Avatar
...Roger...
Hey Bob , remember this one ? It is on the conservative side,the owner came up with the combo. With just 4 gears and the low end torque of the ZZ4 it is a pleasure to drive. It can come from a dead stop burning the tires BUT will also accelerate nicely from 35mph while in 4th gear.
Originally Posted by ...Roger...
Put a ZZ4 in this 69 and the owner loves it.The trans. is a wide ratio Muncie with a 3:36 rear end.
The car is very nice to drive and has quite a bit of punch.
Old Jul 14, 2011 | 05:20 AM
Bob Onit's Avatar
Bob Onit
Wow, Thanks for all the great reply's.
I forgot about Gary, he's only about 20 minutes from me so I'm going to contact him and see and see if he can do the job for me.
From the info posted here I'm leaning towards the 3.55
I'll let you guys know how I make out.
Thanks very much to all for all the help.
Bob
Old Jul 14, 2011 | 05:25 AM
Bob Onit's Avatar
Bob Onit
Yeah, you installed that ZZ4 the same week I installed mine.
I'm just shocked that the engine you installed for him hasn't fallen out yet
Just funnin with ya buddy!
You do great work!
Old Jul 14, 2011 | 12:56 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Out of the various ratios I've had on the street all the way up to 4.56:1, IMHO the 3.55:1 is hard to beat as an all-around gear. My $.02
Old Jul 14, 2011 | 01:35 PM
Bob Onit's Avatar
Bob Onit
Thats what I like to hear
Thanks.
Old Jul 14, 2011 | 01:45 PM
...Roger...
I put a 3:55 and wide ratio in my mid-year 327-350.
Old Jul 14, 2011 | 07:04 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Where can a guy get a ring and pinion set? All I've seen at a few of the vendors is a complete set up with the housing and all.
To Changing differential ratio
