Holley Vacume Leak
Old Jul 16, 2011 | 03:29 PM
63split63's Avatar
63split63
Default Holley Vacume Leak
Hi, I have a 71 small block with a Holley 4801. It runs good and idols good untill after I have ran 20 or 30 minutes and then it seems to develop a vacume leak and a rough idol . I have replaced the base gasket and the gasket between the throttle plate and the carb body with no change .
Any advice would be helpful .
Thanks Bill
Old Jul 16, 2011 | 10:21 PM
JimT's Avatar
JimT
FWIW, check all the external hoses that plug directly into the carb body and base. If one is plugged/capped, check that for leaks. Don"t know how old the carb is but it may need rebuilding. Also check all manifold vacuum hoses. Trouble could be anywhere, so a good start may be to plug all manifold and carb vacuum ports to see if the problem is external to the carb. Good luck.
