Vacuum Questions
Old Jul 16, 2011 | 09:59 PM
Snoopysvet's Avatar
Snoopysvet
Default Vacuum Questions
I have vacuum questions
1978 L-48 ....
1. I want to make sure that the distributor vacuum advance is connected to ported vacuum.
2. I want to make sure the other connections are to the correct vacuum source.
3. Is the check valve bi directional, in other words doe it matter which way it faces to the carb?
4. The TVS units, does it matter if the vacuum source is either on the top or bottom of the unit, or does the unit just open?
5. I can turn the TVS unit's ports, is that ok?
IS THIS OK?
Old Jul 16, 2011 | 11:00 PM
7T1vette's Avatar
7T1vette
1) Why? It will just run hotter and use more fuel when at idle. (just because 'the factory said so' is not a good reason)
2) OK. You have the diagram to do it.
3) No; and Yes...the end you can 'suck' through goes toward the intake fitting. If you can 'suck' through both ends, the check valve is bad.
4) ??? [Not sure what a TVS is.]
5) ???
Old Jul 17, 2011 | 11:30 AM
scottyp99's Avatar
scottyp99
1978 L-48 ....
IS THIS OK?
I can't see any of the photos, so I'll just give what input I can:
1.) On a Q-jet, the ported vacuum is on the front of the carb, pointing straight forward, on the driver's side of the carb. On a Holley, it should be directly above the idle screw on the passenger side of the carb. I recommend hooking your vacuum advance to full manifold vacuum.
2.) Sorry, can't help ya there.
3.)If you don't understand that a check valve is, by definition, a one-way valve, then you probably don't understand the function of the check valve. All it does is allow the vacuum system to be exposed to manifold vacuum when the engine is running, but when the engine is off, atmosphereic pressure can't get into the system, "saving" the vacuum in the system. On a properly operating vacuum system, you should be able to open and close the headlights a few times, just on the residual vacuum in the system.
4.)I have no idea what a TVS unit is.
5.)See #4.
Hope this helps,
Scott
Old Jul 17, 2011 | 12:49 PM
Drawmain's Avatar
Drawmain
TVS is Temperature Vacuum Switch, and it controls the EGR and EFE on these engines. As the engine warms, the switch controls vacuum signal to the heat riser and the EGR valve, and in addition the evap canister. You have a great diagram, so hook it up the way the diagram shows with the lines going from the appropriate ports to the equipment it controls. Turning the ports on the switches may result in snapping them off, so proceed with caution.
Old Jul 17, 2011 | 09:20 PM
Rich's'78's Avatar
Rich's'78
Default Scotty - here goes
I just spent over an hour answering your questions in detail but CF ssems to have dumped my answers.
If you want to phone me after 12:00 EST I will be happy to walk you thru it. 905 338 1434
Richard Rich's'78
Old Jul 18, 2011 | 10:13 AM
7T1vette's Avatar
7T1vette
Rich's 78...
Just some feedback: If you were taking that long to write a response, chances are the system automatically 'dumped' you....assuming that 'no activity' for that long meant you were no longer on-line. I don't think a moderator pulled the plug on you. I've had the same thing happen; I think about 15 minutes or so is the time limit.
Old Jul 18, 2011 | 12:52 PM
Rich's'78's Avatar
Rich's'78
Originally Posted by 7T1vette
Rich's 78...
Thanks. I was checking my old manual to make sure I had everything just right. I wish they would give some kind of warning ........
I was at the computer the whole time. Pi**ed me off!
Old Jul 18, 2011 | 03:40 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The assembly instruction manual (AIM) has a couple of pages of diagrams showing all the hose connections, correct colors, part numbers, etc.
Old Jul 18, 2011 | 05:28 PM
Snoopysvet's Avatar
Snoopysvet
Rich -
I can give you a call tomorrow after 12:00 tomorrow. I don't have an AIM book, maybe in a few weeks I can look into that. Sorry the system timed out on you.
Mark
Old Jul 19, 2011 | 01:27 AM
Drawmain's Avatar
Drawmain
Sometimes its best to write long posts in WordPad or some other word processor, then paste it in here. That way you don't lose all that time and effort, and if you ever need it again, you have it saved on your hard drive
To Vacuum Questions
