Engine oil leak - need suggestions
Got loose on my old engine witch ha a cork gasket, i belive the gasket kompresses and get flat over time.
Also check the timing chain cover.
As earlier mentioned, wash clean so you can see where it comes from.
//Ricky.
I would start on the top of the engine to make sure your valve covers or intake is not leaking. Look around your distributor also. Once the top is clean then start looking around the timing cover and oil pan like Ricky said. That is all the easy cheap items to fix and replace.
Simple green cleaner works also.
Clean the engine with whatever method you choose, different situations require different methods; For your situation, I would go to WalMart and get a couple or three cans of engine degreaser, and follow the directions on the can. If you don't wanna mess up your driveway, do it at one of those do-it-yourself carwashes. (I reccomend this, if you can get away with it, some places won't let ya do it.) Anyway, do whatever you have to do to get the engine nice and clean, the cleaner you can get it, the easier it is to find the leaks.
Now comes the part that sometimes makes people raise their eyebrows. While you are at WalMart getting the degreaser, pickup a couple or three cans of the spray-on foot powder. Yes, spray-on foot powder. let the engine cool down, and spray the foot powder nice and heavy on all the mating surfaces of the engine, just spray it *****-nilly all over the engine. Pretend it is a can of spray paint and "paint the engine white". Once you have a nice thick layer of the foot powder all over the engine, any oil leak will be so obvious that a blind man could see it 10 miles away! Once you know where the leaks are, start fixing them. Sometimes just tightening a few loose bolts will fix a leak, (although sometimes overtightening bolts will make a leak worse, like on valve covers.) Sometimes you need to replace a gasket or seal. Good luck, it's worth the effort involved to fix leaks!
Scott
Also bring a couple of spray cans of engine degreaser. Reach under the car with the spray can and soak the underside of the engine as well as you can. If you can hit some 'hard to get' spots from the topside, go for it.Let soak for 10 minutes or so. Set cycle to 'high pressure soap', hold the wand under the car, and shoot the he!! out of it. There is nothing that low on the engine that will be harmed by the high pressure spray.
Check it out, and if you need to go another 'round', have at it. That should get you clean enough to spot the sources of your engine oil leaks. Sealing them up is another thing altogether. There are LOTS of potential leakage areas...everything with a gasket or seal.
Like I said I have posted this many times. You can purchase a kit at NAPA for about 20 bucks for finding oil leaks, brake leaks, water leaks etc. etc.
The kit is very easy to use. For an oil leak I would simply clean up the motor from the intake, valve covers down, no need to get to get it real clean.
Next you pour one of the dyes from the kit into the oil. Next for easier detection garage so you can turn the lights out and it will be darker in there ( the kit comes with an IR or some other type of flashlight and yellow glasses to see the dye )
Next start the car up with the garage door open, let it run for a couple of minutes and then shut it off. Close the door turn the flashlight on with you yellow glasses on and you will see exactly where the leak is.
The procedure sounds time consuming but once you have bought the kit you can find the leak ( oil, power steering, brake lines etc ) in about 5 minutes, I highly recommend buying the kit, to everyone
Scott
